Date: 25-05-26  Time: 17:08 pm
Author Topic: floppy shifter  (Read 2256 times)
devilsyam
floppy shifter
« on: 27 November 2013, 07:19:43 am »
Is the gear shift return spring in the same place as gen1 on gen 2
PaulSmith
Re: floppy shifter
« Reply #1 on: 27 November 2013, 11:55:15 am »
I don't know bout the gen 2, but is this the spring you mean on the gen 1? http://www.yamahamotorcyclespares.co.uk/genuineparts/9023/19/yamaha%20fzs1000%20fazer/shift%20shaft?uid=0
I usually suffer from floppy shifting if the bolt (14) holding the shift arm(10) to the shift shaft (7) is even slightly loose. Might be worth checking first before you do a strip down.
Tmation
Re: floppy shifter
« Reply #2 on: 27 November 2013, 01:59:45 pm »
Looks like it might be at the other end
http://www.yamahamotorcyclespares.co.uk/genuineparts/9647/20/yamaha%20fz1sa%20fazer/shift%20shaft?uid=0
Part No 1, I have always known them as a detent spring, normally easy to change.
PaulSmith
Re: floppy shifter
« Reply #3 on: 28 November 2013, 11:45:14 am »
Of course the other cause of floppy shifting can be too many pints of Guinness.  :o
