Date: 25-05-26  Time: 21:59 pm
Author Topic: Two or Three brake lines  (Read 3358 times)
chr999chr
« on: 19 November 2013, 01:10:28 pm »
Was looking to replace my front brake lines. Whats the difference in the 2 or 3 line standard or race. Is there any benefit fitting one or the other
http://www.helperformance.com/motorcycle/yamaha/fzs1000/
bigbluebear
Re: Two or Three brake lines
« Reply #1 on: 19 November 2013, 03:59:16 pm »
I've gone for two, no splitter from the master cylinder.
Falcon 269
« Reply #2 on: 19 November 2013, 05:26:44 pm »
If you decide to go for a 2-line set, I suggest you look at Venhill because their fittings are adjustable.  You might find that this helps with getting the lines to curve correctly down to the calipers.
I had a HEL 2-line set for a while but wasn't happy with the routing and reverted to a 3-line set until I fitted R1 forks.  Because I needed custom length lines for the R1 front end, I had Venhill make them up for me and the adjustable fittings work nicely.
bigbluebear
« Reply #3 on: 19 November 2013, 05:37:42 pm »
I had mine measured as I have Renthal 773 bars so were custom made to fit from Hel
mickvp
  • Global Moderator
« Reply #4 on: 19 November 2013, 05:42:55 pm »
Ive got a 2 line goodridge setup. no difference bar the splitter is gone AFAIK.
dickturpin
« Reply #5 on: 19 November 2013, 06:17:43 pm »
3 line from hel...which also have adjustable fittings.
Hedgetrimmer
« Reply #6 on: 19 November 2013, 06:19:50 pm »
I've had both set-ups in the past, no discernible performance difference, had no problems with routing. Just personal preference really.
Tmation
« Reply #7 on: 20 November 2013, 02:18:04 pm »
I have the 3 line Venhill setup on mine and am very happy with them.
I have had Earls and HEL in the past (2 and 3 line set ups), and the Venhills seem nicer (and easier to line up).
2 line front is a requirement for proddy racing (well it used to be), its also cheaper than the 3 line.
Just my 2p worth.
JoeRock
« Reply #8 on: 20 November 2013, 03:11:09 pm »
Two lines, it's easier to bleed mainly!
nickodemon
« Reply #9 on: 20 November 2013, 10:12:59 pm »
+1 :)
Dave48
« Reply #10 on: 20 November 2013, 10:57:05 pm »
Just fitted Goodridge 2-line front  & (obviously) single rear. My bike is an 03 600 & the original rubber hoses were well past their "best before" date! Have also replaced the brake caliper seals, cleaned & checked everything, applied red rubber grease to outer edges of pistons & also overhauled master cylinder with "Yamaha" kits. Nice new fluid & bled easily. Oh yes, copper grease applied sparingly to back of brake pads and pad pins. Job done-sorted! :D
