Date: 08-05-26  Time: 06:05 am
Author Topic: Changing my coolant - any tips  (Read 27242 times)
Dave48
Re: Changing my coolant - any tips-- Here you are Andy Clap
« Reply #50 on: 22 November 2013, 08:41:54 am »
It wont flow out the drain hole UNTIL you remove the rad filler cap under tank!! :lol
thunderpantz
« Reply #51 on: 22 November 2013, 08:50:52 am »
That said, I remove the drain bolt prior to removing the filler cap. If there are any leaks the fluid should trickle out. If the fluid doesn't budge then the system is air tight
His Dudeness
« Reply #52 on: 22 November 2013, 09:47:08 am »
Just take the lowest hose off and sorted. You'll get a bit more out too because the hose is lower than the the drain bolt.
andybesy
« Reply #53 on: 22 November 2013, 12:23:23 pm »
I think its only the yzf which has drain on cylinder
« Reply #54 on: 22 November 2013, 12:54:51 pm »
How many blokes does it take to undo a bolt?  :lol
« Reply #55 on: 22 November 2013, 01:23:28 pm »
No need to take off the hose and there is no engine drain bolts just 1 bolt on the pump thats it.
cap on blolt out, bucket under- cap off ---take a pissing photo - kick bucket closer to bike as pressure drops.
His Dudeness
« Reply #56 on: 22 November 2013, 04:49:13 pm »
Or just punch a hole in the rad with a flathead screwdriver it'll soon drain out. better yet kick the rad off then you don't even need the screwdriver :lol
CRH
« Reply #57 on: 23 November 2013, 05:38:27 pm »
...yep?....with the dude on this one!! ;) ...but watch you dont damage the fan when you kick the rad off" :rolleyes .....
hightower
« Reply #58 on: 01 December 2013, 07:53:38 pm »
Which will explain why I spent 30 minutes looking for something that wasn't there.....
