Date: 07-05-26  Time: 15:23 pm
Author Topic: Renthal 758 bars  (Read 19797 times)
Chris
Renthal 758 bars
« on: 08 November 2013, 12:59:47 am »
Hi all,
It would seem that Renthal 758's are the bars to go for but my question is where to get them from?
I've found some on ebay: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350920968084
and some on M&P's website: http://www.mandp.co.uk/productinfo/539600/Bars-and-Footrests/Universal-Bars/viewitems.aspx
The ones on M&P's website have a different clamp dimension size from the ebay listing and both bars linked above have slightly different dimension sizes to the 758 bars on the Renthal website, even if it's only a few mm different for most of the measurements...
So, which should I go for/where did you get yours?
Chris
stevierst
Re: Renthal 758 bars
« Reply #1 on: 08 November 2013, 05:47:11 am »
I've had a few sets now from different places, they all felt the same. If they're proper Renthals, then they're going to be Renthal dimentions I would have thought.
Chris
« Reply #2 on: 08 November 2013, 05:50:10 am »
That's what I thought too but just wasn't sure how the two linked above had such different dimensions for the clamp area.
Chris
stevierst
« Reply #3 on: 08 November 2013, 05:51:37 am »
You can get them from demon tweeks for £27.99 free postage.
Just put "renthal ultra low" in eBay search bar and they'll come up in the first few listings.
Chris
« Reply #4 on: 08 November 2013, 05:59:17 am »
Ah cheers mate, totally forgot to check there.
These ones: http://www.demon-tweeks.co.uk/motorcycle/handlebars/renthal-superbike-ultra-low-bars
They have them listed as superbike ultra low and most other places have them as 758 or road ultra low... very confusing...
dimensions quoted are slightly different again by a few mm haha. Thanks though, I'll go for them though.
Chris
« Reply #5 on: 08 November 2013, 06:10:04 am »
Questions i keep meaning to ask, as they are called "ultra low" are they actually lower than original bars or similar?
And i know they're a little wider than standard, but in regards to fairing clearance are they the same, better, or worse?
Chris
« Reply #6 on: 08 November 2013, 06:13:38 am »
from what I can work out from others posting on here then they are similar height to the standard but have less sweep + slightly wider and therefore more comfortable on the wrists.
As for clearance on the fairing etc then I've asked before and people said the 758's were fine.
Chris
stevierst
« Reply #7 on: 08 November 2013, 06:14:44 am »
On my last boxeye, they only just missed the fairing. As for the name, well it's just a name that renthal give them.
And they're a hell of a lot more comfy! Slightly wider but more importantly, less sweep. Best 'comfort' mod you can make to a fazer in my eyes.
« Reply #8 on: 08 November 2013, 09:07:58 am »
So, i presume when fitted there's still not enough space for hand guards then?
stevierst
« Reply #9 on: 08 November 2013, 11:47:00 am »
Erm...... No.
« Reply #10 on: 08 November 2013, 12:22:57 pm »
trudd
« Reply #11 on: 08 November 2013, 12:47:05 pm »
[size=78%]Questions i keep meaning to ask, as they are called "ultra low" are they actually lower than original bars or similar?[/size]
Renthal "low" 754's are very close to the standard bars so Ultra lows will be a bit lower.
andybesy
« Reply #12 on: 08 November 2013, 01:17:01 pm »
Do the controls on the FZS have the little bits which need filling off to fit new bars?
Andy
Chris
« Reply #13 on: 08 November 2013, 02:22:55 pm »
Yes they do have the little lugs that need trimming down or you can drill the bars but I don't really want to do that.
Chris
apage16
« Reply #14 on: 08 November 2013, 02:35:00 pm »
Chris
Especially as the official line is that if you drill the bars it invalidates your warranty. Apparently if Renthal drill bars for OE use, the drilling is done before the hardening and anodising stages so strength isn't affected.
I just stuck a bit of heat shrink where my switchgear goes, it's steady as a rock. In fact before, it could move a tiny fraction due to the lug being SLIGHTLY loose in the hole on the bars. Now they don't budge a nanometer!
Chris
« Reply #15 on: 08 November 2013, 02:54:30 pm »
Good point apage  8)
Chris
Chris
« Reply #16 on: 08 November 2013, 04:40:40 pm »
Just done this search on ebay and when you search then demon tweeks are first on the list at £27.99 with free postage but when you click on the advert then it says it's £11.99 postage... Going to contact them and see what the deal is.
If you buy direct from their website then the bars are £27.98 with £3.54 postage.
Chris
Skippernick
« Reply #17 on: 08 November 2013, 08:51:39 pm »
Erm...... No.
Damn.....  :\
Does that mean you have found hand guards that fit the normal bars?
stevierst
« Reply #18 on: 08 November 2013, 08:53:37 pm »
I Just stick to muffs, gave up on handguards.
CRH
« Reply #19 on: 08 November 2013, 08:56:29 pm »
........+1 there matey ..cant beat a good muff" :b ...keeps ya ears warm at least?
« Reply #20 on: 08 November 2013, 10:19:28 pm »
Erm...... No.
Damn.....  :\
If i find bars with enough clearance then trust me i WILL find hand guards, i've always wanted some!
stevierst
« Reply #21 on: 08 November 2013, 11:01:10 pm »
I hope you'll  you share the secret when you find the frosties secret formula!
« Reply #22 on: 09 November 2013, 01:29:29 am »
Leave that one with me, taking the biting wind off the fingers is a simple but major solution  :D
stevierst
« Reply #23 on: 09 November 2013, 08:28:28 am »
Oh yeah! I had them on my tiger, very effective especially with heated grips. Oooh, lovely!
Chris
« Reply #24 on: 09 November 2013, 09:28:43 am »
That is one of the main reasons I want to change my bars just now. I have some R&G heated grips to put on but want less sweep on the bars so don't want to waste them by putting them on my standard ones as it'd probably wreck them taking them off if I wanted to replace the bars afterwards.
Chris
