Date: 26-04-26  Time: 06:59 am
Author Topic: Engine Temp warning light  (Read 4965 times)
BorisTheThird
« on: 29 October 2013, 02:39:18 pm »
The LED in my rev counter that comes on when the engine gets too hot doesn't work, and wants replacing (no continuity over it)
I was assuming it was 12v, but then my brother sugested it may not be the obvious 12 v, anyone know what it should be?
cheers
Boris
Motorbreath
Re: Engine Temp warning light
« Reply #1 on: 29 October 2013, 02:52:32 pm »
LEDs do not fuse, they are very tough. Have you tested the temperature sensor first?
BorisTheThird
« Reply #2 on: 29 October 2013, 03:09:46 pm »
no, but i know the LED is duff (was taking the clocks apart anyway and tested it).
Also, the fan does still come on
andybesy
« Reply #3 on: 29 October 2013, 03:22:02 pm »
I think when turning on the ignition it should come on briefly as a test anyway, irrespective of the sensor.
Andy
« Reply #4 on: 29 October 2013, 03:39:30 pm »
Quote
Not on a 98
savvy
« Reply #5 on: 29 October 2013, 03:47:50 pm »
Warning 'Newbie question here' I have a 1998 600 fazer and until this post didn't know about temp warning light. Could someone please give location and operation of this? :o
Many thanks Barrie
BorisTheThird
« Reply #6 on: 29 October 2013, 04:03:18 pm »
Many thanks Barrie
its on the rev counter, just past the 15krpm mark
« Reply #7 on: 29 October 2013, 04:22:01 pm »
isnt there a temp symbol next to it also +- or somthing
BorisTheThird
« Reply #8 on: 29 October 2013, 04:47:22 pm »
theres a picture of a thermometer in some water
Ebme Geek
« Reply #9 on: 29 October 2013, 04:52:44 pm »
LED's can not be checked with a normal continuity test, they need to be checked using a diode test, and will have a forward bias voltage of approximately 2v. And yes they are polarity sensative.
Do not put a LED straight across 12v either without it having a current limiting resistor in series, otherwise it will go puff.
Some have an internal resistor, but vast majority do not
Will check manual later and get back to you if you can check it by pulling the wire of the top of the sensor and shorting it against it's body, the only diagram I have here does not show a resistor, and the sensor symbol is slightly odd, so I want to check the resistor is not in the sensor, it should be just a switch but ??
AdieR
« Reply #10 on: 29 October 2013, 06:10:31 pm »
Not being familiar with the FZS, and not having a diagram, I'd assume the clock unit takes a 12V feed, and any lower voltage supply rails will be generated within the clock unit itself via a regulator on the PCB.
LED's seldom fail (as stated by someone else, they don't respond well to "normal" testing), maybe you're seeing a problem that isn't there?
savvy
« Reply #11 on: 29 October 2013, 06:12:14 pm »
Thanks for the info on the location of the light. Barrie
john 087
« Reply #12 on: 29 October 2013, 06:35:31 pm »
Have my 98 fazer nearly 4 years now, the light or the fan never came on.
Motorbreath
« Reply #13 on: 29 October 2013, 08:05:45 pm »
 As said, you need a diode tester. Also the fan and the light have different sensors, both at the thermostat housing. The smaller one for the light. On my bike the fan's one stopped working.
Unplug the wires from the sensor and make a jumper and see if the light works.
BorisTheThird
« Reply #14 on: 29 October 2013, 08:31:12 pm »
cheers, ill try tomorrow :)
Ebme Geek
« Reply #15 on: 30 October 2013, 12:14:17 am »
Yep as I eluded to earlier and as Fizzy Pies has put up go for grounding the wire to check the indicator: Haynes section 3 subsection 5
