Date: 07-05-26  Time: 05:37 am
Author Topic: Charging system issues  (Read 24569 times)
BorisTheThird
Re: Charging system issues
« Reply #25 on: 23 October 2013, 07:58:57 pm »
ime no electrical wizard but ive always been under the impression that you should never disconnect a battery whilst engine running can do all sorts of damage?...all you got to do is leave in situ and connect a meter across the batt terminals and see what it reads both on idle then when its reved to 3 t 4thou it should be approx 14.2 + at about 4thou...little less with lights etc loaded up!!...unfazed or fazerider will give you the correct figures ;)
Yep a very bad idea disconnecting battery while engine running,if you have an alternator.
 Whilst you may well get away with it at tickover (if you're lucky), there's a good chance of blowing the regulator as you've excess power with nowhere to go without a battery to soak it up.... & if your regulator goes( without a battery as well!) you're in with a really good chance of screwing up something expensive as the charging voltage skyrockets.
Please keep the battery connected  ;)
Carefully Check ALL charging circuit connectors are clean & not loose before you go any further.... will save unecessary expense in replacing good parts, don't ask how i know that  :o
but surely without the battery there is no circuit, so current cannot flow
CRH
« Reply #26 on: 23 October 2013, 08:06:34 pm »
....read what unfazed has just posted previous page?
69oldskool
« Reply #27 on: 23 October 2013, 08:17:06 pm »
Yes,as  mine was kinda 'The Sun' readers version. :lol
CRH
« Reply #28 on: 23 October 2013, 08:19:44 pm »
...soz old school ment you too? ;) .....
69oldskool
« Reply #29 on: 23 October 2013, 08:24:28 pm »
 :lol :lol :lol
« Reply #30 on: 23 October 2013, 08:26:08 pm »
A serious misunderstanding of alternator based charging systems here.  :wall  The battery and the load is what the regulator looks at to determine the charging rate. The battery is part of the charging circuit. Take the battery out and the regulator will increase its output trying to charge a non existent battery which will fry the regulator and if it short circuits internally it will put 20 volts AC out to the load and fry the ECU and then fry the Alternator insulation.
Ignore the warnings as your peril  :moon
BorisTheThird
« Reply #31 on: 23 October 2013, 08:29:14 pm »
Thanks for the vote of confidence Foccers :)
Under no circumstances should you remove the battery with the engines running on alternator based systems, especially on bikes (or cars) with ECUs and Electronic Regulators.  :eek The systems are not designed to run without the battery. The fazer has an ECU and an electronic rectifier/regulator which is normally called the Regulator. Fazer Alternators are 3 phase Alternating Current (AC) devices and the AC is converted by the Rectifier to direct current (DC) and the Regulator controls the DC output based on the battery condition and electrical load.You will most likely fry the Regulator and after frying that you are likely to fry the ECU and then the Alternator. Lucky for you the bike stopped and the worst you may have done is fry the Rectifier/Regulator unless you have a faulty alternator, in which case you are lucky.Disconnect the plug from the regulator and the resistance between the white wire connectors should be between 0.36 to 0.44 Ohms. (Don't know where you got you info. from)  :thumbdown There should be no reading from the white wire connectors to the frame (earth). If the resistance is higher the output will be lower and if there is continuity to earth output will be lower again.Your reading is on the high side but could be from a bad connection between the meter and the connectors.The resistance readings on their own are not enough to prove the alternator is good. You could have insulation break down when under load or when hot. Set the meter to AC and with everything connected start the bike and check the voltage between the white wires; (push the meter leads (carefully) into the back of the plug) it should read around 18 to 20 volts AC. With the engine running at tick over the voltage across the battery should read over 12v and go up to an absolute maximum of 14.4 when the engine is revved over 5000 revs. If the voltage does not increase and you have 19 to 20v AC from the alternator then the regulator is faulty.
couple of things, do you know how the rectifier works, i was expecting just a simple bridge rectifier, capacitor and a voltage regulator. but from what you say its more involved.
also, would a flat battery or blown main fuse no cause the same issue?
ive tested the voltege output from the stator, got about 90v (which is what someone on another forum says i should be expecting)
69oldskool
« Reply #32 on: 23 October 2013, 08:41:46 pm »
No,Not a bridge rectifier~
 reg/rectifier is a 3 phase rectifier  coupled with a voltage regulator circuit all in one unit. think they're a bit more technical than the used to be ~Unfazed?
Andy FZS
« Reply #33 on: 23 October 2013, 08:49:54 pm »
The forum is very educational, electrical principles part z.
Ok onward,  I'm listening not falling asleep after being to pub at dinner as I did in my college days lol
Andy
BorisTheThird
« Reply #34 on: 23 October 2013, 09:05:59 pm »
so simmiler to this?
69oldskool
« Reply #35 on: 23 October 2013, 09:30:42 pm »
My bikes broken :cry2:
 Mr Haynes says i cant test the rectifier, i can either swap it for a known good one or take it to a yam dealer to do it....
Mr Haynes also says "caution: never disconnect the battery cables from battery whilst the engine is running...." Hmmm.....just maybe he's onto something. :evil
However,
Mr Yamaha says:( & he should know i guess ;) )
http://foc-u.co.uk/index.php?action=downloads;sa=view;down=8
In the official factory manual,yes you can test the rectifier, download & have a good read of the electical section.
Whatever "this" was in last post it's not showing on my computer.???
Not being funny Boris, but i'd be more bothered 'bout fixing my bike than debating every point brought up, there a helpful lot here,& they're only trying to help. :\
« Reply #36 on: 23 October 2013, 09:35:17 pm »
Usually 18 to 20 v AC is at tickover and is could be as low as 17 and as high as 25 depending on the tickover speed. The AC voltage levels increase dramatically as the revs increase, it could increase to 100 v AC +, which is why I would not recommend testing it higher than say 2000 revs unless you have the proper meter with the proper insulation ratings. I don't know what the Fazer ones go to as I never at any reason to try.
The Alternator is a 3 phase unit and requires 6 diodes to convert it to DC. The reason 3 phase is used is that it gives a smother DC output before the addition of capicators and maybe coils to smooth it to a clean DC.  See first Picture.
The regulation can contain some complex electronics to control the regulation of the voltage under various load condition. The second picture is an example of one of the newer type Japanese rectifier/regulator.  A bit more involved than the old single phases bridge rectifier circuit :)
In answer to the question, yes a blown main fuse can cause the same problem.
A flat battery would have the same effect, but not as quickly as a blown fuse or disconnected battery. That is the reason why you should change a battery that goes flat regularly as it puts more load on the regulator.
Doddsie
« Reply #37 on: 23 October 2013, 09:37:31 pm »
Im lost, Ill just stick to cleaning mine!!
« Reply #38 on: 23 October 2013, 09:38:35 pm »
 :agree
BorisTheThird
« Reply #39 on: 23 October 2013, 09:44:32 pm »
However,
Thanks, not trying to be annoying, just trying to understand how things work (i cant fix the bike till tomorrow now so m stuck inside on the pc :P)
and in the last post i was trying to post the first picture in this
http://webpages.charter.net/jrandall/vrr/vrr_upgrade.htm
« Reply #40 on: 23 October 2013, 09:45:07 pm »
Any chance you could come and clean mine  :rollin
Doddsie
« Reply #41 on: 23 October 2013, 09:48:25 pm »
Ill trade ya next time i have an electrical problem!! ;)
69oldskool
« Reply #42 on: 23 October 2013, 09:50:08 pm »
 :lol :lol :lol
69oldskool
« Reply #43 on: 23 October 2013, 09:52:06 pm »
However,
Ok,no worries.
 & yes similar to that diagram.
Andy FZS
« Reply #44 on: 23 October 2013, 09:53:43 pm »
Well I'm learning things I hope I'll never need to know,  but then I know lots of things that nobody needs to know.
BorisTheThird
« Reply #45 on: 23 October 2013, 09:57:30 pm »
However,
Ok,no worries.
Im learning thing i really should know, i deal with these (ish) in my job - just 50kv AC - 650v DC ones  :eek
CRH
« Reply #46 on: 23 October 2013, 09:59:24 pm »
...hope t fk it doesnt involve paul and dolly" :b :b :b :b :b
Andy FZS
« Reply #47 on: 23 October 2013, 10:15:43 pm »
When it comes to Paul and Dolly there are lots of things I don't want to know at my young age;D
Paul
« Reply #48 on: 24 October 2013, 05:37:23 am »
In the old brit bike world lots of people run bikes without batteries, they use the Boyer ignition box set up.
I have a Honda Innova which will start and run with no battery on it, but I caveat that with you have to use the kick start and the clocks don't work unless you connect the battery.
Oddly enough you can take the battery off and kick it up and it starts just as easily as if it had a battery on it.
And the main headlight is on permanently (you can't turn it off).
Although maybe it's been specifically designed like that for places where there is no way of charging a battery up.
« Reply #49 on: 24 October 2013, 10:49:51 am »
FWIW, the generator on the Fazer (and most bikes) is a magneto i.e. an alternator using permanent magnets. The term alternator just means ac generator, but is generally used to refer to those that use electromagnets rather than permanent ones to provide the magnetic field: they're bulkier but more efficient and are what cars use.
In theory, disconnecting the battery while the engine is running needn't cause a disaster. The regulator will continue to limit the peak voltage and, while the rectified ac will be very lumpy without a battery, the ignition should cope. However, it's not something I'd care to try and I agree with all the advice you've been given: as a diagnostic technique it stinks. If the regulation had failed volts could rise high enough to nuke the ignition unit and instruments.
The stator coils should measure 0.36 to 0.44 ohms so yes, yours sound about right (you'll probably be within spec if you subtract the measurement you get when shorting the multimeter leads together).
If the battery charger you used as a supply is a simple transformer and rectifier type, then the volts dipping to zero fifty or a hundred times a second would probably have starved the ignition and that is what stopped the engine in your test.
Provided there's decent continuity in the rest of the charging circuit then I'd agree the rectifier is probably to blame.
The easiest way to check is by substitution. I've never tried testing mine, my Yamaha manual doesn't give details, but if is a simple bridge rectifier and shunt regulator arrangement it should be easy to check. On the other hand, if it uses SCRs in the bridge to reduce the power the thing has to dissipate when the magneto is at full output I'll agree with Mr Haynes that it's too complicated to test with a multimeter.
