Date: 03-05-26  Time: 04:38 am
Author Topic: cold starting  (Read 2418 times)
dickturpin
cold starting
« on: 23 September 2013, 10:07:27 pm »
The last two times I have started the bike from cold it's taken many attempts to catch. (I don't use choke)
I'm not sure if this is a problem or not yet and will see how the next few go. bike has a new battery with loads of umph so not that.
What would you set about checking?
Its not ivanised (that I know of).
When it does fire its very lumpy until I can gradually increase revs. When its warm it runs fine so I don't think its a carb balance problem. It also starts straight away when warm.
This isn't a major issue yet but looking for suggestions to investigate.
I realise all stock fazers can be a little tricky to start but the last couple have seemed worse.
slimwilly
Re: cold starting
« Reply #1 on: 23 September 2013, 10:22:31 pm »
Weak spark,why not use choke?
Maybe petrol wet plugs, or bad plugs
dickturpin
Re: cold starting
« Reply #2 on: 23 September 2013, 10:41:35 pm »
Never really needed choke....maybe half choke in winter that's all.
Capt
Re: cold starting
« Reply #3 on: 23 September 2013, 10:49:52 pm »
Use the choke that's what it's for, Ivanising reduces the need of the choke when cold but it will still need it.
devilsyam
Re: cold starting
« Reply #4 on: 23 September 2013, 11:02:25 pm »
pre ivan always use choke even then may be two attempts but capt is spot on
dickturpin
Re: cold starting
« Reply #5 on: 23 September 2013, 11:23:50 pm »
ok, i'll try next time...maybe I've just got into bad/lazy habits!
