yep, they are permanently fixed to the coils.
But its so strange for it do to it,
I have had the bike laid up for a month for repairs (chain came off on the way back from scotland and took out the clutch push rod) and after the new front tyre went on and some fresh petrol which was after about 100 or so miles of use to get the back tyre all bedded in, she started acting up.
It was solved with cleaning the plugs, but only for one ride out.
New plugs had gone in (the set in her were from her April service at a local garage) and she ran fine for a month, so thought nothing of it till that she started doing it worse then before.
Stripped her down and found the fuel filter was full of shit so replaced it, took her out again with a small improvement.
Out came the diaframs, they were ok and no sign of damage, the top of the carbs got a clean and the reservoirs were drained and flushed out. Number one came out cloudy but nothing else from the rest. The coils were checked for damage and number 2 cap popped right off, so trimmed and screwed that back in.
Took her out again, with some more improvements to the point it was now in my cruising revs, which is more annoying.
So i'm left with trying to get some working coils and my friends Fazer is in a dispute with Yamaha over this 'drive sprocket' issue so i can't go near it.
