I have an 04 Gen 1. It has always run great...... until now. It sits in my heated garage and doesn't get used very much. It has developed a fault where its not keen to start, when it does start it runs very rough. I assumed it was old petrol blocking the slow running jets. I warmed it up and took it out. Its missing up to about 2500 and then seems to pull like a train. I have taken it to our highest hill and come down the other side on a closed throttle to suck out the blockage. No change. I then added carburettor cleaner, let it site and tried again. This time I also took it to our local dual carriageway, up to about 70mph and the closed throttle, again to try and suck out any debris. No change.
I took the bike to my local garage . He has checked it over and found cylinders 1 & 4 are not getting hot so he changed the plugs. No change. He then checked the electrics and found no spark on 1 & 4. He fitted a new coil pack. No change. I have just let him test my ECU from my 05 Gen 1. No change
We are stuck. Does anybody have any ideas what might be causing this problem please?
Obstructed/blocked Pilot circuit/jets or both.
Later
That was our first thought until we found Nos 1 & 4 had no spark. It is a big job to remove the carburettors. If it isn’t a blockage, is there any chance it could be anything else? If no other possibilities then we will have to bite the bullet.
Thank you for your input Gnasher.
Had something similar last year. There were a number of issues all contributing. High resistance plug caps, one of the coils degrading when warm and also ignition switch wiring high resistance.
Tricky to sort as it was always fine when first starting out, started to misfire after 10 minutes or so.
Time to get the multimeter out and go through it if you can.
We now have a spark on No 1 but no spark on No 4. New plugs, obviously new leads on the coil pack. I think next step is to remove carburettors. I know that won’t help spark issue but at least we will know there are no blockages. If we can’t get a spark I might need to try an auto electrician. I don’t really want to go to a dealer, had a bad experience with one a long time ago and it’s put me off, besides, I don’t think we’ve got any decent ones you could trust in this neck of the woods.
Make sure you check the resistance of the plug caps with them off the coil. Should be around 10K ohm. If they are not you can unscrew the resistor inside and give it a good clean up. If they go high resistance, in the Mega Ohm value, they will cause misfires.
Update - cleaned the carbs, the bike has covered 120k miles so probably needed it. It’s a little fluffy just above tick over but I’m hoping a carb tune will resolve that. Apparently, very dirty inside carbs. Thanks to those that responded.
Ivans kit is always a good move! ?
So how did you fix the no spark issue? With a bike laid up for a long time blocked pilot jets is the most likely issue, so I’m curious about what fixed the persistent no spark problem.
FZS 1000 Gen1 (2003)
Tiger 900 GT Pro (2020)
We changed one of the coil packs and all spark plugs.
I have another Fazer 1000 in the garage and the carbs are so gummed up I can’t move the throttle twist. This Bio Fuel is proper crap.
