Odd fault... rough running. Sooty plug.
I wonder if anyone's seen this...
After about an hour's riding, I'm getting rough running, but only at low speeds and pulling away. Idle is fine. Higher speed is fine. At the lower speeds, I'm getting popping and banging on the over-run. Lumpy power delivery. Exhaust sounds bubbly/burbly.
But idle is fine and higher speeds are fine.
When the fault is active, header #4 is noticeably cooler - 80°C when the others are around 180°.
Spark plug #4 is sooty.
Initially, I replaced two spark plug caps that were out of service limits (resistance).
I then swapped plug caps around and changed the coil and HT leads on the #1/#4 pair. But the same problem happens, #4 header is cool and #4 plug is sooty. So I think I've excluded ignition as the problem.
I then took the carbs out, thinking that carb #4 must be gummed up or the float / fuel level high or something. But the carbs are surprisingly clean. The only thing I've found in the carbs is some weird silvery muck on the sliders and #4 was the worst of them. I've cleaned the carbs up, checked the jets, diaphragms, etc. I will properly check the float heights and fuel levels but the floats look fine by eye.
Anyway, that's where I'm at. It just occurred to me that it could be a known common fault that someone can explain so I thought I'd post.
Cheers!
2001 FZS 1000, 53,000 miles
Well, a couple of the float heights were outside service limits...
Has adjusting the float heights sorted it?
(10-10-26, 01:28 PM)Trebus Wrote: Has adjusting the float heights sorted it?
I was reinstalling the carbs when I noticed that the throttle closing cable was frayed so I'm waiting on new throttle cables to arrive. Will post when the job's done.
The Haynes manual said to check the fuel levels with the carbs in the bike... that sounded like a nightmare, though - it's so packed in tight under there. Routing tubes through and reaching the drain screws when they're installed would have been really awkward. And if the levels were wrong, the carbs would have to come out again! So I mounted them on a step ladder and checked them there - much easier. All perfect.
I will synchronise the carbs while I'm doing all this, too. It's a 25-year-old bike so it's gonna need a little TLC. The Haynes manual said I should replace all rubber seals and O-rings, etc. But I'm tight so I didn't. Actually, I didn't want the delay of sourcing them. If this don't fix the problem, I'll reconsider.
The floats had been sitting high in all four. I suspect the needles and needle seats have worn so the floats were travelling further before they seated.#2 and #4 were particularly high and they were the sparks that were darker than the others. #4 was clearly sooty whereas #2 was just dark and looked a bit unhealthy.
A nice easy place to find those parts - https://www.richardmarksbikeparts.com/co...-2001-2005
(15-10-26, 12:08 AM)RMT1983 Wrote: A nice easy place to find those parts - https://www.richardmarksbikeparts.com/co...-2001-2005
That's an awesome site - I'll bookmark.
Reminds me of the old FJ Owners club that ran through the 90s and 00s - a monthly or quarterly booklet packed with articles, letters, adverts... all focussed on the FJ and the membership was something like £5 a year that basically covered the printing and postage.
Now the Internet has destroyed the printing and postage costs... and destroyed membership along with it... that hard copy in your hand that is a focus of community. Now there's just an ocean of webpages instead, mostly dross.
Anyhoo - thanks! I know where to go when the bike still has the fault and I decide on a proper carb refurb.
Its my website ?
I decided that as there was nothing currently fazer focused then I would take on the job!
(15-10-26, 09:44 AM)RMT1983 Wrote: Its my website ?
Nice one.
I'll be placing an order for the exhaust valve bolts at some point - saves picking a close match at the local fastener suppliers.
I've looked at a few 2001 Fazers and it looks like mine is one of the few that still has a fully working power valve. Every other year - Coppaslip everything!
But not before I've got this fault sorted - might wanna combine an order to save on P&P.
So, I said I'd post when the job was done... it's done. I balanced the carbs while I was at it.
The bike is now running... I would say that it's now running just like it did when I bought it 15 years ago!
The engine is running sweet again, pulling like a train, smooth and powerful. I get a little popping occasionally on the overrun but that's the replacement exhaust can and I quite like it. With the power on, it's really smooth again. It idles really smooth and starts real easy now.
The brakes... I would say that the brakes are pretty-much as good as the Brembos on my 2019 Triumph. The Fazer is the only bike that I've ever done a stoppie on and I just love the brakes - great power and feel.
The suspension is also has a really nice feel to it. Solid and plenty of feel while soaking up bumps really well. In fact, the rear suspension is much better than that on my Triumph which is far too harsh for the size of bike.
So yeah - it was the float heights that were out, causing the rough running. And they needed the balancing - they were quite far out.
Just need some sunny days now...
Beautiful. I’m sure I read a comment from Falcon many years ago that float heights on Fazer 1000s were rarely out of tolerance. Great news you’ve sorted it.
(25-10-26, 08:26 PM)Trebus Wrote: Beautiful. I’m sure I read a comment from Falcon many years ago that float heights on Fazer 1000s were rarely out of tolerance. Great news you’ve sorted it.
I've been riding and doing my own maintenance for 40 years now and I've had carbs apart before several times but I don't recall ever having to set float heights before... to be honest, I was using ChatGPT to help diagnose the problem. It doesn't get everything right but I do find it useful. When we'd ruled out ignition problems, it suggested cleaning the carbs and checking  the float heights. ChatGPT for inspiration plus Haynes manual for reliable info - good combo.
If I were doing it again, I'd use a proper carb rebuild kit, though. Still, it's running fine for now!
Well, after all my claims of the old bird being in fine fettle and the suspension being great, it just got an advisory on the MoT because the rear suspension's failing!
It seems that although it currently feels fine, it's now leaking and so will soon fail.
Ah well, it is 25 years old. So, dear Google, will it be a new unit or a second-hand one!?
I just hope it's not too much of an arse to fit...
There’s normally an abundance of gen 1 shocks available second hand. Mainly, because they weren’t great from day 1 and people have chucked them off for aftermarket, R6 or BMW options. Shocks from other bikes need mods to bushes, springs and dog bones.
It’s fairly easy to swap it over if you either a like for like replacement or a modded shock with the pre-work done.
