outside temperature display
Added another gadget today: an outside temperature thermometer. I mounted the sensor on the underside of the fairing, facing the airflow. The display is secured with a homemade bracket to the right handlebar clamp near the brake fluid reservoir, where I also mounted the reservoir for the chain lubrication system.
I did make the third bracket, however, partly to adjust the optimal viewing angle from the saddle. The display (weighs almost nothing) is secured with Velcro, as the two batteries will eventually need to be replaced.
.jpg   01 display-DS.jpg (Size: 94.47 KB / Downloads: 16)
.jpg   02 sensor-DS.jpg (Size: 57.49 KB / Downloads: 16)
