Balls - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 8 / FZ8 (https://foc-u.co.uk/mybb/forumdisplay.php?fid=76) +--- Thread: Balls (/showthread.php?tid=83953) |
Balls - Pal - 14-01-26 Changed to headstock bearings on my 2014 Fazer 800 as they had a definite 'detent' in the straight ahead position, and was very surprised to find that they were balls and not taper rollers. Have changed them to taper rollers with a kit from a bearing place in Aldershot. I would expect balls on a smaller bike, but not on something this size. I believe the frame is similar to the Fazer thou, do they have balls as well? I had a FZS600 previously and I'm sure it was taper rollers as standard on that. RE: Balls - unfazed - 15-01-26 Yes, the 600 and 1000 have ball bearings.⁷ RE: Balls - Trebus - 15-01-26 I’ve never had a bike with tapered bearings from the factory. Most of the problems in my experience are from lack of grease from the factory causing premature wear. One of the first jobs I do on any new (to me) bike is strip / clean / grease the headstock bearings. RE: Balls - unfazed - 15-01-26 (15-01-26, 07:21 PM)Trebus Wrote: I’ve never had a bike with tapered bearings from the factory. Most of the problems in my experience are from lack of grease from the factory causing premature wear. One of the first jobs I do on any new (to me) bike is strip / clean / grease the headstock bearings. The XT225 Serow has a taper roller bearing on the bottom of the steering stem and and a Ball bearing type at the top from the factory |
