Putting bike away for winter - Printable Version
+--- Thread: Putting bike away for winter (/showthread.php?tid=83907)
Putting bike away for winter - Patlawlor - 31-10-25
Hi,
2001 FZS600 36k miles.
Is there a thread on what I will need to do to put the bike away for the winter since I  won’t be able to ride it for a while.
Cheers
RE: Putting bike away for winter - b1k3rdude - 31-10-25
I should technically know the answer to this, as I have two bikes and they both live outside. But I imagine someone with more knowledge/exp will be along shortly -
Depending on how long you don't ride it -
- first clean the bike, then with a clean microfibre cloth, give the entire bike a rubdown with GT85/ACF50.
- discs, typically you never spray anything on these. But if the bike is laid up for months, then wiping them over with an oily rag (dont spray, as you might get it on the pads) and then cleaning off with brake cleaner before riding again.
- chain, its a good time to clean and then re-lube the chain.
- all lever joints, side/center stands, should get a squirt of GT85/ACF50.
- stuff an oily rag into the end of the exhaust, reducing moisture ingress.
- if outside put a water resistant cover over the bike, if inside a dust cover.
RE: Putting bike away for winter - Gnasher - 31-10-25
Assuming it's a FZS with crabs and you don't want to ride it until the spring. Disconnect the fuel supply, run it until it stops, wash it, put protectrant on it, put the battery the battery on charge.  job done.
RE: Putting bike away for winter - Schomosport - 31-10-25
I sometimes say hello to them and give them a pat as I walk through the garage. Other than that I monitor battery voltage and put them on charge as necessary. Worked perfectly well for my single seater racing cars for many years, don't see why bikes should be any more fragile. Probably also a good idea to check tyre pressure now and then.
RE: Putting bike away for winter - Patlawlor - 01-11-25
Thanks for advice from everyone.
It it sufficient just to disconnect fuel and run until it stops or do the carbs need to be drained too?
Cheers
RE: Putting bike away for winter - Gnasher - 01-11-25
(01-11-25, 09:46 AM)Patlawlor Wrote: Thanks for advice from everyone.
Cheers
It's stops because there's no fuel or very little in the bowls, which will evaporate.  If you can then open the float bowl drains, then yes open them.  That said be careful there are often seized and either, snap or crumble half out, stopping you from resealing them.  If that happens you're going to have to the float bowls to fix it/them.
Personnelly I don't do anything beyond washing and putting the battery on charge when I store a bike.  My XJR1300, was not used for 18 months, it had E10 fuel in it and started on the button and rode perfectly.
All of the above is on the assumption your bike isn't having starting or any other issues and don't go starting it up every week/month or so.  That's what kills them, just leave it alone until you want to start using it again.
RE: Putting bike away for winter - Faze2 - 01-11-25
Cheers
Hi, I just put fuel stabilizer in the tank (E5 fuel) run it through and then top off the tank for the fuel system its never let me down.
For the rest just make sure its clean then protect everything , wax spray is good for paintwork etc and a wax for your chain too , outside try keep tyres off the ground, remove the battery or trickle charge.
Mine is kept outside so after prep and treatment I use some cardboard around the engine, soft old towels over the top ,an old duvet and two covers ( one is never enough  Big Grin), thick cardboard under the tyres.
Oiling like others have said, lube the stand.
Happy storage  Cool
Thanks everyone.
RE: Putting bike away for winter - Gnasher - 02-11-25
Cardboard and duvet around the engine why? It doesn't need to be kept warm it's made of metal and those are just going to trap and hold water/moisture/damp etc.
RE: Putting bike away for winter - b1k3rdude - 02-11-25
Indeed, if anything and if you want to be proactive, just some airflow to evaporate any moisture. And the last time I looked most garages/sheds are draughty AF.
RE: Putting bike away for winter - Faze2 - 04-11-25
(02-11-25, 09:13 AM)Gnasher Wrote: Cardboard and duvet around the engine why?  It doesn't need to be kept warm it's made of metal and those are just going to trap and hold water/moisture/damp etc.
I live in the wilds where temps can drop below -10 and 15ft snow drifts ,so i just like to ensure the cooling system is ok. Like I said bike is kept outside and the windchill can be quite severe. Not had any problems so far   Big Grin
RE: Putting bike away for winter - Gnasher - 04-11-25
(04-11-25, 03:37 PM)Faze2 Wrote: I live in the wilds where temps can drop below -10 and 15ft snow drifts ,so i just like to ensure the cooling system is ok. Like I said bike is kept outside and the windchill can be quite severe. Not had any problems so far   Big Grin
Each to their own. Ready mix UK Anti freeze goes down to -35 ish, it's never getting anywhere near that even in the wind. I've got mates in Scandinavia that don't see those temperatures nowadays! Admittedly their mix is 50/50 or in the extreme north 60/40 in their cars.
RE: Putting bike away for winter - Faze2 - 05-11-25
Thumbup Thumbup Big Grin
RE: Putting bike away for winter - fazersharp - 08-11-25
If the area that you keep it is subject to outside temperature then if we have few days of very cold and as happens quite a lot in this country -the next day the temperature has gone from 2 degrees to 15 then the very cold metal parts will be covered in condensation. So If its really cold for a few days and you see the forecast is +++ loads of degrees then that is the time to go and cover the engine / whole bike and by slowing down the temp change you will prevent condensation forming.
RE: Putting bike away for winter - Faze2 - 14-11-25
It can also protect the inlet rubbers and other rubber/ plastic parts from splitting, becoming brittle. Its an old bike and needs all the help it can get  Cool
