2000 Fazer FZS 600 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 2000 Fazer FZS 600 (/showthread.php?tid=83801) |
2000 Fazer FZS 600 - David Evans - 18-06-25 The bike had been standing for 12 months with fuel in tank with an additive, she did not fire up changed fuel started after a time,but will not idle only if you keep choke on revs, ok any suggestions to my situation thanks. Dai RE: 2000 Fazer FZS 600 - BBROWN1664 - 18-06-25 Sounds like the carbs are clogged and would benefit from a clean - blocked idle jets. RE: 2000 Fazer FZS 600 - David Evans - 18-06-25 Thanks for the reply I forgot to mention that I had cleaned the carbs look's like I need to take another look at them. BR Dai RE: 2000 Fazer FZS 600 - BBROWN1664 - 18-06-25 Did you balance the carbs after and reset the TPS? RE: 2000 Fazer FZS 600 - unfazed - 18-06-25 (18-06-25, 10:40 AM)David Evans Wrote: The bike had been standing for 12 months with fuel in tank with an additive, she did not fire up changed fuel started after a time,but will not idle only if you keep choke on revs, ok any suggestions to my situation thanks. Blocked pilot jets, very difficult to clean as they are not a straight hole, but have a star/web structure inside. Soak in Carb cleaner over night in a sealed container to prevent Carb cleaner evaporating. Blow them through from both directions. Maybe soak them again for a few hours and blow them through again. A ultra sonic cleaner is good if you have acces to one. RE: 2000 Fazer FZS 600 - David Evans - 18-06-25 (18-06-25, 02:59 PM)BBROWN1664 Wrote: Did you balance the carbs after and reset the TPS? Once again thank you for your reply, I will have to find who can do that, too much knowledge more than I have. BR Dai RE: 2000 Fazer FZS 600 - Faze2 - 21-06-25 (18-06-25, 07:10 PM)TPDavid Evans Wrote:TPS is pretty simple ( if its working correctly) youtube vids on TPS and carb balancing , pretty easy to do , save yourself some money and feel the pride when its running sweet.(18-06-25, 02:59 PM)BBROWN1664 Wrote: Did you balance the carbs after and reset the TPS? RE: 2000 Fazer FZS 600 - unfazed - 21-06-25 (21-06-25, 11:44 AM)Faze2 Wrote:An out of adjustment TPS on the Fzs600 has very little effect on the FZS600 running, but a faulty one can cause annoying surging at different speeds and as the speed increase it is less noticible. It is a very basic set up on the 600 and only advances the timing slightly based on throttle opening and bike speed. The 1000 on the other hand is effected more because the EXUP valve is tied to it, as is the the speed of the bike. It is on the fuel injected models where it becomes a much bigger issue because of all the sensors.(18-06-25, 07:10 PM)TPDavid Evans Wrote:TPS is pretty simple ( if its working correctly) youtube vids on TPS and carb balancing , pretty easy to do , save yourself some money and feel the pride when its running sweet.(18-06-25, 02:59 PM)BBROWN1664 Wrote: Did you balance the carbs after and reset the TPS? The important thing with the TPS is to adjust it after balancing the carbs and setting the idle speed. The 600 is one of the easiest bikes to adjust the TPS on. You just need Securty Torx bit No. 25 and driver for the bit Turn on the ignition with the Kill switch on, Disconnect the TPS and reconnect it The Tacho needle will go to 0, 5,000 or 10,000 revs The correct position is 5,000 If at 0 or 10,000 loosen the Security Torx bolts a little and move it forward or backwards. When it is set to 5,000 tighten the bolts bot be carefull not to overtighten them. If it moves when tighten adjust it to the 5,000 When your happy with the adjustment and all is tightened up turn off the ignition. Thats it Disconnecting the TPs with ignition switched on puts it into Diagnostic mode, turning off the ignition resets it. |
