Gen 1 1000 Carb O'rings dimensions? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Gen 1 1000 Carb O'rings dimensions? (/showthread.php?tid=83773) |
Gen 1 1000 Carb O'rings dimensions? - Gaz66 - 09-05-25 Hi. Any chance anybody has saved info carb O'ring dimensions? Can't find anything on forum, seem to remember admin saved it as a sticky, but no sticky info seems to be visible on carbs now forum's been updated. Rgds Gaz ? RE: Gen 1 1000 Carb O'rings dimensions? - PieEater - 09-05-25 Information is in the FAQ in the Carb section; With age the rubber O rings in the carbs can deteriorate leading to a number of issues with the bike running roughly especially at lower revs / speeds. Given the age of the OEM O rings it is recommended to replace these using Nitrile (Buna-N) or VitonĀ® (FKM) O-Rings, Fluoroelastomer Seal type FKM 75 in the following sizes; - Float needle valve: 7.5mm ID x 1.5mm cross section x 10.5mm OD - Main Jet : 5.5mm ID x 1.5mm cross section x 8.5mm OD - Idle air screw: 3.0mm ID x 1.0mm cross section x 5.0mm OD - Under Diaphragm cap 2.5mm ID x 1.5mm cross section x 5.5mm OD - Idle air screw O-ring is a proprietary size of 2.70 I.D. x 1.13mm RE: Gen 1 1000 Carb O'rings dimensions? - Trebus - 09-05-25 Attached info, from unfazed. RE: Gen 1 1000 Carb O'rings dimensions? - Gaz66 - 09-05-25 (09-05-25, 10:21 PM)Trebus Wrote: Attached info, from unfazed.Thanks (09-05-25, 10:02 PM)PieEater Wrote: Information is in the FAQ in the Carb section; Nice 1, appreciated |
