Tyre wear experts - Printable Version
+--- Forum: Diesels and Lawnmowers (Bike racing n things) (https://foc-u.co.uk/mybb/forumdisplay.php?fid=73)
+--- Thread: Tyre wear experts (/showthread.php?tid=83763)
Tyre wear experts - stevierst - 27-04-25
Calling tyre wear experts. Has anyone got any idea why my rear Bt023 might be wearing like this? Suspension settings maybe?
RE: Tyre wear experts - Grahamm - 27-04-25
I have a vague recollection of Russ (from Russ' Tyres in Portsmouth) telling me that it was caused by (I think) too low tyre pressure when he was repairing a slow leak in one of mine.
RE: Tyre wear experts - stevierst - 28-04-25
Cheers Graham, thought similar myself. I had a check once the tyre cooled down an hour after I got home and it's 38psi which is what I put it at.
I did have a play yesterday with a rider on a 1290 superduke across the Hawes to Ingleton road and we were pushing it a bit. It's a very grippy road surface that one.
RE: Tyre wear experts - agricola - 28-04-25
Definitely suspension. I was on a website lsat week looking at wear patterns and what they are likely to indicate prior to a trackday, but for the life of me I cant remember what it was, but that particular pattern was mentioned
Had a play with the shock tonight, and the rebound was 2 clicks from max (s1000rr shock)
Could be something to do with it maybe?
RE: Tyre wear experts - agricola - 29-04-25
It maybe, the site also had imaages of the reverse ie a lip on the forward edge of the groove (sipe?) and provided possibilities form the causes of both. Fecked if I can find it now though
Try this one https://www.youtube.com/watch?v=Cqq5dEiADJY
RE: Tyre wear experts - Grahamm - 29-04-25
(28-04-25, 09:50 PM)stevierst Wrote: Had a play with the shock tonight, and the rebound was 2 clicks from max (s1000rr shock)
That should only affect how the bike feels, eg if you hit two bumps in quick succession, does the second feel worse because the shock still hasn't rebounded fully from the first?
RE: Tyre wear experts - stevierst - 30-04-25
Yeah it did feel like the back was jacking up a bit, and it was getting a out of shape and squirrely on rough bends when pressing on.
(29-04-25, 08:45 PM)agricola Wrote: It maybe, the site also had imaages of the reverse ie a lip on the forward edge of the groove (sipe?) and provided possibilities form the causes of both. Fecked if I can find it now though
Just watched that video, and it's interesting stuff. I watched the Dave Moss videos, but he was a bit too track tech for me.
This bloke has pointed me in the rebound direction with the feathering being on the rear of the sipes.
Cheers, much appreciated.  Big Grin
RE: Tyre wear experts - kralik - 05-02-26
Hi,
I know, this is bit late to answer, but from my knowlodge and if I remember some talks with other people, this should be quite standard wear from braking, even from braking with engine brake. When you look at it well, you can see that the wear is in the oposite of acceleration direction. All my old tyres have the same, even on my old track bikes/tyres (R1).
But, yes, someone can bring even more light into this topic as well.
RE: Tyre wear experts - BBROWN1664 - 06-02-26
(05-02-26, 02:57 PM)kralik Wrote: I know, this is bit late to answer, but from my knowlodge and if I remember some talks with other people, this should be quite standard wear from braking, even from braking with engine brake. When you look at it well, you can see that the wear is in the oposite of acceleration direction.
The lips are caused by slightly warm tyres gripping and the thin (at that point) edge of rubber folding as accelerating whilst leant over - in this case on a right hand bend/roundabout - not from braking
RE: Tyre wear experts - midden - 23-04-26
Suspension set up
