Temperature Guage Mod - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Temperature Guage Mod (/showthread.php?tid=83734) |
Temperature Guage Mod - BSR67 - 14-03-25 All Is there a temperature guage mod that people have carried out? Conscious there is no guage, and that apparently water pumps are prone to failing, is there a conversion/adaptation kit that anyone is aware of? Thanks BSR67 RE: Temperature Guage Mod - PieEater - 15-03-25 Which bike? The Gen1 1000 has no issues with water pump failure as far as I'm aware, but just in case it is a Gen1 send a private message to forum member schlumpf as he used to make a great multigauge for the Gen1. RE: Temperature Guage Mod - Trebus - 16-03-25 Here’s some info on the multigauge. Sadly no longer available but occasionally pop up second hand. I have one on my bike. https://www.cartestsoftware.com/fz1/multigaugeinstallation.html RE: Temperature Guage Mod - BSR67 - 20-03-25 (15-03-25, 06:01 PM)PieEater Wrote: Which bike? The Gen1 1000 has no issues with water pump failure as far as I'm aware, but just in case it is a Gen1 send a private message to forum member schlumpf as he used to make a great multigauge for the Gen1. Sorry yes, Gen 1. Not sure where I'ce read it (on here?). Thanks BSR67 RE: Temperature Guage Mod - Trebus - 21-03-25 There have been a few reported incidents of water pump seals leaking, vent pipe through the sump I believe. Fair bit of work to fix it but seals can be obtained. RE: Temperature Guage Mod - BSR67 - 23-03-25 (21-03-25, 02:05 PM)Trebus Wrote: There have been a few reported incidents of water pump seals leaking, vent pipe through the sump I believe. Fair bit of work to fix it but seals can be obtained. Thank you. Tempted to service it before it keels over! BSR67 RE: Temperature Guage Mod - PieEater - 26-03-25 I'd be more tempted to go with the principles of "if it aint broke don't fix it" / "ride more worry less" |
