FZ1N 2006 Speedometer onto a FZS1000 2001 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: FZ1N 2006 Speedometer onto a FZS1000 2001 (/showthread.php?tid=83676) |
FZ1N 2006 Speedometer onto a FZS1000 2001 - 2BALD4YOU - 30-11-24 Question: I’m trying to install a 2006 Yamaha FZ1N digital speedometer on my 2001 Yamaha FZS1000 Fazer. Both models use the same 16-pin (2x8) connector, but the pin configurations and the wire colors seem to differ. I have scoured the web trying to find something to help me and have spent many hours trying to figure out the wiring diagrams in the service manuals . However, as I’m new to this stuff, it turned out to be a bit more difficult than I thought. The only diagram I’ve found for the pin layout is for the FZS1000, which I’ve attached below. As much as I understand from the wiring diagrams in the service manual, I believe this pin layout seems to be correct.
FZS1000 maping.png (Size: 104.62 KB / Downloads: 132)
I can’t seem to figure out the FZ1 2006 pin layout, though. I was really hoping it would be plug-and-play, but here we are! Could someone provide a detailed pinout for the FZ1N speedometer, including wire colors and functions? If anyone has experience with this swap, how do I rewire the FZS1000 harness to work with the FZ1N speedometer? Are there any signal compatibility issues I should look out for (e.g., tachometer or speed sensor)? Any help would be greatly appreciated! RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - unfazed - 02-12-24 Not possible, as the FZ1 Gen 1 instrument cluster is ECU controlled, only option is the 2000/2001 R1 clocks, but you lose the fuel guage as it only has a reserve light. 19988/1999 wont work ans it does not have Coolant Fan Motor Relay control see the downloads for the pin outs of 600, 1000 and both carburettor models of the R1. I will upload a file I created when investigatng fitting a digital type instrument cluster to the 1000 with the instrument cluster pin outs of both versions of the carburettor R1 models, the Fzs1000 and the 3 versions of Fzs 600 RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - 2BALD4YOU - 02-12-24 Here’s a polished version of your text: --- Hey Thanks so much for your reply. From what I understand, it seems like the FZ1N speedometer won’t work on my bike. What other aftermarket speedometers could I use, or what should I look for in a compatible unit? My goal is to convert the bike into a naked version while upgrading the speedometer, as the stock one feels quite clunky. Also, you mentioned a file you created with the pinouts—could you please share it here? I don’t seem to see it attached. Thanks in advance for your help! (02-12-24, 01:21 AM)unfazed Wrote: Not possible, as the FZ1 Gen 1 instrument cluster is ECU controlled, only option is the 2000/2001 R1 clocks, but you lose the fuel guage as it only has a reserve light. 19988/1999 wont work ans it does not have Coolant Fan Motor Relay control see the downloads for the pin outs of 600, 1000 and both carburettor models of the R1. RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - unfazed - 03-12-24 Managed to upload it this evening and it is waiting for admin approval Correct FZ1 one won.t work. The easiest option as I said is the 2000/2001 R1 5JJ model, but you will need to move around a few pins in the cable connector on the harness I am not sure what other clock will fit as the control of the Fan is the main issue RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - BBROWN1664 - 03-12-24 (03-12-24, 12:56 AM)unfazed Wrote: Managed to upload it this evening and it is waiting for admin approval Apologies, i didn't get a notification but its all approved now. RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - unfazed - 03-12-24 (03-12-24, 11:42 AM)BBROWN1664 Wrote:(03-12-24, 12:56 AM)unfazed Wrote: Managed to upload it this evening and it is waiting for admin approval No bother RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - 2BALD4YOU - 03-12-24 I’m fairly new to forums, so I’m still figuring things out. Could you clarify where I can find the attached file? Should it already be visible to me? Additionally, could you guide me on which pins I would need to change once i get the R1 to get the speedometer? Thanks again for taking the time to reply! ? RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - unfazed - 03-12-24 Click on the bike at the top and you will see in in downloads RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - 2BALD4YOU - 15-12-24 (03-12-24, 12:56 AM)unfazed Wrote: Managed to upload it this evening and it is waiting for admin approval Hey, since you seem to be an expert in this area I have another question. Since the R1 clock doesn’t have a fuel gauge, could I theoretically connect an aftermarket fuel gauge using the already installed fuel level indicator in the tank, or something similar? RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - unfazed - 15-12-24 Would never consider myself an expert, however there is a reserve light on the R1 clocks like there is on the Fazer clcoks which will work. Yes you could theoretically connect an aftermarket fuel gauge or something. RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - 2BALD4YOU - 19-12-24 (15-12-24, 10:52 PM)unfazed Wrote: Would never consider myself an expert, however there is a reserve light on the R1 clocks like there is on the Fazer clcoks which will work. Hey, I received my R1 clock today and made the necessary changes to the pins on the connector. I connected all the pins according to your sketch and double-checked everything. Everything seems to be working—fan kicks in and all systems appear functional. Now, regarding the fuel setup: I’ve decided not to pursue a fuel gauge and will rely on the fuel reserve light instead (Which i didint know it had before). However, I’ve encountered an issue—the fuel reserve light is constantly on, even though my tank is full. On the old clock everything also worked correctly. Do you know what might cause this? Could there be a way to fix it so the light functions correctly? I have attached a picutre below. Dont mind the oil light, it went away after the photo. RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - Grahamm - 19-12-24 Just as an observation, the F 0.1km indicates you're just into reserve whcih is why the warning light is on. I'd check whether it's actually getting the right signal from the tank level sensor. Personally, on my FZ6, I never bother with the fuel gauge, I just reset the Trip 1 counter to 0.0 when I fill the tank and know that in summer I get 200 miles full tank to reserve and in winter it's 175 full to reserve. Once the display switches to F 0.0 I know I've got a theoretical maximum of approximately 40 miles before it's completely empty. RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - unfazed - 20-12-24 (19-12-24, 02:16 PM)2BALD4YOU Wrote:(15-12-24, 10:52 PM)unfazed Wrote: Hey, RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - 2BALD4YOU - 23-12-24 (19-12-24, 11:38 PM)Grahamm Wrote: Just as an observation, the F 0.1km indicates you're just into reserve whcih is why the warning light is on. Thanks for pointing that out, but the tank's full, so I don’t think it’s a reserve issue. Also, the trip is set to 0, so that’s not the counter till reserve. I’d rather figure out how to get the gauge working properly than just rely on the trip counter. (20-12-24, 05:10 PM)unfazed Wrote:(19-12-24, 02:16 PM)2BALD4YOU Wrote:(15-12-24, 10:52 PM)unfazed Wrote: Hey, If you do get a chance to check the sender unit you have in the garage over Christmas, I'd be very grateful for any findings. Do you think switching the wires definitely wouldn’t be enough? If adjustments are needed, what kind of modifications would I need to make? Let me know if there's anything specific I could provide or look into to assist with figuring out the values of the R1 sender. Thanks again for your help! RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - unfazed - 26-12-24 No easy way to modifiy the FZS1000 sender, but looking through my infomation, the 3 wire sender from the 1998 to 2001 sender should work. This has a thermistor to operate the fuel light unlike the the later Foxeye models and the FZS1000 as these used the Instruments ECU to control it. Of the 3wires from the Sender of 1998 to 2001 Boxeye Fzs600, the Green/Red and Black wires are the ones for the Thermistor are the ones to use. The third wire is for the guage will not be used RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - 2BALD4YOU - 05-01-25 (26-12-24, 09:23 AM)unfazed Wrote: No easy way to modifiy the FZS1000 sender, but looking through my infomation, the 3 wire sender from the 1998 to 2001 sender should work. This has a thermistor to operate the fuel light unlike the the later Foxeye models and the FZS1000 as these used the Instruments ECU to control it. Hey! Happy new year! I just want to make sure I understand correctly before placing the order for the required part. When you refer to the "fuel sender," are you referring to the pumping unit or the fuel level meter unit? Additionally, I haven’t been able to locate a part with 3 wires. Could you please clarify your response and, if possible, share a picture of the part in question? Your help would be greatly appreciated! RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - unfazed - 06-01-25 There are two types of thermistors: Negative Temperature Coefficient (NTC) and Positive Temperature Coefficient (PTC) With the NTC thermistor, when the fuel level drops below it the resistance decreases, with the PTC thermistor, when the fuel level drops below it the resistance increases. The Early FZS600s most likely had the NTC, but I do not know what type is in the R1 See picture of the fuel senders. Looking again at the Fuel sender of the 1000 you probably could modifiy it to take the R1 sende by removing the electronic board and desoldering from the connectors and attach the R1 unit to it and solder the wire to the appropriate connector. Make up a link from the stand to the second wire connector RE: FZ1N 2006 Speedometer onto a FZS1000 2001 - schlumpf - 19-02-25 Two more remarks to this conversion: The R1 secondary transmission ratio is 43/16. The FZS1000 ratio is 44/16. Thus the speedo will read low by about 3%, which nicely compensates all (built-in) errors to 0. The resistance of the original R1 thermistor is ~1k ohm when submerged and cooled by the fuel. In "free air" the temperature increases up to 85°C due to self heating and the resistance drops to ~ 100 ohm. The missing-tank-thermistor issue can be solved in different ways. My recommendation is #3: 1. Fixate the float in a proper position and mount a R1-thermistor to it. 2. Use some electronics to convert the quasi-continuous float-resistor to NTC behaviour. 3. Emulate the NTC by modifying the original fuel sender. The fuel-sender is a stepped-switch. Cut all unnecessary lines. Only the empty-position remains connected (~95 ohm in total). Add 2 resistors as per drawing (external or on the ceramic). By this the float-resistance is switched between ~250 ohm (empty) and 1500 ohm (all other positions). |
