can someone identify this ticking noise. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: can someone identify this ticking noise. (/showthread.php?tid=83541) |
can someone identify this ticking noise. - MeteorStorm - 02-07-24 Hi, I recently did a DIY job on my motorcycle splitting the engine case and replacing second gear on my fzs1000. All went well and now i can dry my bike again woop woop. However i'm having an unknown ticking sound. Maybe a bolt is loose, or is that the sound of cam chain rattle, or something worse? please advise. It's worse coming off throttle which would suggest cam chain, but there's just also alot more vibration when you release throttle...so i'm not sure. https://drive.google.com/file/d/13KRSUXjmy_FlAD__YXaUaf69AYhFjATO/view?usp=drive_link that's the mp3 file. :'( Re: can someone identify this ticking noise. - Trebus - 02-07-24 I think I’d be getting the rocker cover back off and see what’s going on. Hopefully nothing too major. Re: can someone identify this ticking noise. - PieEater - 02-07-24 First thing that came to mind is there's a known issue where the plug that sits in the centre of the assembly pops out, so could be worth taking the cover off to make sure everything's OK. Re: can someone identify this ticking noise. - MeteorStorm - 02-07-24 (02-07-24, 11:40 AM)PieEater link Wrote: First thing that came to mind is there's a known issue where the plug that sits in the centre of the assembly pops out, so could be worth taking the cover off to make sure everything's OK. What cover exactly? and the rocker cover...that hasn't come off...didn't do nothing with the cams etc... So i wouldn't suspect anything there? Re: can someone identify this ticking noise. - PieEater - 02-07-24 DOH'T - Sorry the clutch cover, there should be a plug in the middle of the assembly. Re: can someone identify this ticking noise. - b1k3rdude - 04-07-24 (02-07-24, 08:05 AM)MeteorStorm link Wrote: I recently did a DIY job on my motorcycle splitting the engine case and replacing second gear on my fzs1000. All went well and now i can dry my bike again woop woop.However i'm having an unknown ticking sound.Have you checked where the sounds is coming from exactly, as in take a long screwdriver and place it against parts of the engine and then your ear against the end of the screwdriver handle... - like a stethascope. Otherwise take it to a indipendant one man motorcycle mechaic and get him/her to listen to it. RE: can someone identify this ticking noise. - MeteorStorm - 09-07-24 (04-07-24, 09:35 AM)b1k3rdude Wrote:(02-07-24, 08:05 AM)MeteorStorm link Wrote: I recently did a DIY job on my motorcycle splitting the engine case and replacing second gear on my fzs1000. All went well and now i can dry my bike again woop woop.However i'm having an unknown ticking sound.Have you checked where the sounds is coming from exactly, as in take a long screwdriver and place it against parts of the engine and then your ear against the end of the screwdriver handle... - like a stethascope. Good Idea, I'll try that, cause it's very hard to locate! Greetz RE: can someone identify this ticking noise. - MeteorStorm - 16-10-24 (09-07-24, 04:23 PM)MeteorStorm Wrote:(04-07-24, 09:35 AM)b1k3rdude Wrote:(02-07-24, 08:05 AM)MeteorStorm link Wrote: I recently did a DIY job on my motorcycle splitting the engine case and replacing second gear on my fzs1000. All went well and now i can dry my bike again woop woop.However i'm having an unknown ticking sound.Have you checked where the sounds is coming from exactly, as in take a long screwdriver and place it against parts of the engine and then your ear against the end of the screwdriver handle... - like a stethascope. fyi: It was the exup that had a little bit of play, sounded like ticking from a chain or something but was the exup...fixed. RE: can someone identify this ticking noise. - Trebus - 17-10-24 Simple stuff first. Thanks for the update.
