K-tech Shock Springs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: K-tech Shock Springs (/showthread.php?tid=83539) |
K-tech Shock Springs - Gaz66 - 01-07-24 Hi guys. I've a selection of K-tech shock springs for sale. These are a selection of stronger springs in the same dimensions as fitted stock to an R6 shock which many of us have fitted, useful to have if you find the stock R6 spring to be too weak & your getting too much static sag. Springs have done no work as used only for testing on another bike project. Below are the springs I have for sale: ID=55/ Length=155/ Rate=115N/mm ID=55/ Length=155/ Rate=125N/mm ID=55/ Length=155/ Rate=160N/mm Price is £50 each posted, UK only, payment via Paypal or £45 collected (Barnsley, S/Yorks) Thanks for looking. RE: K-tech Shock Springs - Anto - 09-01-25 Are any of these still available? Edit: After looking, a bit closer, I don't think that these would work for what I'm looking for, sorry for the mistake RE: K-tech Shock Springs - Gaz66 - 08-03-25 (09-01-25, 06:40 PM)Anto Wrote: Are any of these still available? Can I ask for what project you need springs & why you think these won't work for you? RE: K-tech Shock Springs - Anto - 08-03-25 (08-03-25, 12:23 AM)Gaz66 Wrote:The project that I'm doing is taking an R6 shock and putting it on the FZS600.(09-01-25, 06:40 PM)Anto Wrote: Are any of these still available? It's been a while since I've done the research (I've had all of the parts ordered and ready for a while) so I honestly can't really remember why I said these won't work for me, sorry to not be or any help here. RE: K-tech Shock Springs - Gaz66 - 08-03-25 (08-03-25, 12:33 AM)Anto Wrote:(08-03-25, 12:23 AM)Gaz66 Wrote:The project that I'm doing is taking an R6 shock and putting it on the FZS600.(09-01-25, 06:40 PM)Anto Wrote: Are any of these still available? Different spring rates & more importantly different shocks were fitted to the R6 product run, the shock u have & intend to use may not use same spring dimensions as the ones I'm selling, you'd only confirm this by pulling the spring from the shock & measuring it up, or if you know the exact model year bike the shock came from, you can search on K-techs site & it gives OEM spring rates, spring & shock dimensions for most shocks. Your shock spring will likely be more than adequate for a Fazer600, bear in mind any changes to the stock dog bones or linkage can drastically affect the weight of spring required, as does rider/load weight, but you'll not know how the spring will perform until it's fitted & you can take static bike sag & rider sag measurements. ? |
