Fazer 1000 high beam issue - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fazer 1000 high beam issue (/showthread.php?tid=83522) |
Fazer 1000 high beam issue - Tommy666 - 22-06-24 Hello I have a problem with my Fazer and wonder if anyone can help me out, the lights are permanently on with no switch provided to turn them off , when I start the bike and use either the flasher or high beam switch the rev counter drops briefly to zero and all the warning lights on the dash illuminate for a couple of seconds then normality is returned, however it only performs this unusual trick on first using the flash/dip switch ?♂️ I have never noticed this issue until I took it for the MOT and the tester pointed it out to me , I should say the bike passed its test as all lights work normally, a mate has the same bike and has the same problem, hopefully someone will have had this issue and found the solution Regards Ian Re: Fazer 1000 high beam issue - old son - 23-06-24 I think there is a multi cable connector to the Speedo housing. That might not be making a good connection. Try giving it a good clean. Also check your earths. Re: Fazer 1000 high beam issue - Tommy666 - 24-06-24 Hello, my mate and me have had every block connector apart and they were all clean as a whistle , however it does seem that when high beam is used there’s a big voltage drop ?♂️. Thank you for your reply ? Re: Fazer 1000 high beam issue - Gnasher - 25-06-24 There's a short in the positive circuit somewhere, it's probably in the loom as it goes around the headstock or in and around the head light unit. It's could also be a connector. Being clean doesn't mean there's no shorts.
