Steel T pipe front of engine - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Steel T pipe front of engine (/showthread.php?tid=83514) |
Steel T pipe front of engine - Phill nailer - 17-06-24 Hi All, if anyone is having a problem with the steel T pipe on the front of the engine drop me a message. I know you can't get them anymore,as I spent ages trying to so I've had one made at work from ali Re: Steel T pipe front of engine - fazersharp - 17-06-24 I dont recognise that part - where does it fit - looks like part of the coolant pipes ? Re: Steel T pipe front of engine - Phill nailer - 18-06-24 Yes front coolant pipe on right hand side of engine, mine rotted out around the weld between the 10mm joint. They are no longer available anywhere! My second MK1 is going the same way so will be making more if anyone is interested Re: Steel T pipe front of engine - fazersharp - 18-06-24 (18-06-24, 01:06 PM)Phill nailer link Wrote: Yes front coolant pipe on right hand side of engine, mine rotted out around the weld between the 10mm joint. They are no longer available anywhere! My second MK1 is going the same way so will be making more if anyone is interestedI see. Good work. |
