Freshly rebuilt bike was firing on 4 cylinders, now down to two - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Freshly rebuilt bike was firing on 4 cylinders, now down to two (/showthread.php?tid=83404) |
Freshly rebuilt bike was firing on 4 cylinders, now down to two - Unstoidable - 26-02-24 Hello Bike has been off the road for 18 months, finally managed to solve a leaky carb issue and rebuilt the bike. Had a leak on the tank valve, so emptied the tank and put in some fresh petrol when I changed it out. Bike started, ran on 4 cylinders for a while, and now is down to the left 2? Seems to be running quite rich as well, I can smell the petrol as its running. Any suggestions? Would very much like to get it back on the road and MOT'd soon, ready for the summer. Thanks in advance Re: Freshly rebuilt bike was firing on 4 cylinders, now down to two - BBROWN1664 - 26-02-24 if its running on two, the other two will be pumping un-burnt fuel into the exhaust making it seem rich. That's assuming the carbs are not blocked. Are the coils connected correctly? left hand one (as you sit on teh bike) connected to #1 & #4 and the right hand one connected to #2 & #3? Does it run on all 4 at higher revs (above 4-5k)? Re: Freshly rebuilt bike was firing on 4 cylinders, now down to two - Unstoidable - 26-02-24 Coils connected properly, because i've done that before :lol I will check when I next go out to it, it ran on all four to start with then number 3 and 4 exhausts were clap cold after 5 minutes Re: Freshly rebuilt bike was firing on 4 cylinders, now down to two - unfazed - 26-02-24 Are you sure you didn't put plug lead 3 on plug 4 and plug lead 4 on plug 3. Very easily done and looks right, especially if the leads on the tags are missing Re: Freshly rebuilt bike was firing on 4 cylinders, now down to two - Unstoidable - 27-02-24 All leads have numbers on them still, so all connected up correctly Re: Freshly rebuilt bike was firing on 4 cylinders, now down to two - unfazed - 27-02-24 When it was idle was it on the side stand the whole time? If it was the most likely issues is blocked pilot jets |
