Power Tweak or Relay for Ignition Switch Relief - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Power Tweak or Relay for Ignition Switch Relief (/showthread.php?tid=83294) |
Power Tweak or Relay for Ignition Switch Relief - jul1us - 25-08-23 As announced in the Ivan thread, I'm bringing this method called "Power Tweak" here from the German Fazer forum in case anyone here has use for it. The goal is to strengthen the headlight and relieve the ignition switch. Not sure if this has been done here before. Background by Christian (Schlumpf): "From the outset, it has surprised me why the Fazer despite double headlights only a relatively modest, average light emitted. Over time, it turned out that the wiring is not the greatest and swallows a lot of "precious" voltage. I finally looked into the matter and found a workable solution. With one or two additional cables, depending on the requirement, the Fazer electrics can be helped on the jumps. I have described the conversion on my website. The "standard" voltage loss at the headlight of about 2.8 volts can be reduced to about 0.6 volts." Christians (Schlumpf) method can be found here: https://cvieth-bplaced-net.translate.goog/motorrad_licht.html?_x_tr_sch=http&_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=en The German forum then found two simpler methods. "There are 3 variants to improve the light, in all of them the effect occurs that the light becomes better and the ignition lock is relieved from the load current of the light.
Conclusion regarding the ratio of effort to benefit: Variant 3 is the least time-consuming and has almost the same effect as variant 1. Power Tweak is in my opinion the best solution, since only slightly more effort is required than with variant 3 and the ignition lock is relieved the most." So here is the translated guide by fzmoe for variant 3 "power tweak" with a schematic at the bottom: "The idea came from Chris on the Fazer forum, you can read the idea behind it there. Parts list:
Remark: Since approx. 19 amps could flow at maximum load with this circuit, a cable cross-section of at least 4mm2 is required for the switching circuit. Instead of the 4mm2 cable, you can also use two 2.5mm2 cables connected in parallel, these are more common and almost every screwdriver has them lying around somewhere. The blue/brown cable to be modified on the Fazer from the ignition lock to the fuse box is also a parallel cable. Relay pinout:
Steps:
Here is the schematic with the modifications: https://i.imgur.com/MHH3wWP.jpg Cleaned up post and linked in 'Gen1/2 Fazer 1000: Common maintenance & tasks' thread. - bkd Re: Power Tweak or Relay for Ignition Switch Relief - unfazed - 25-08-23 Diagram suitable for the early models with the lights on/off on the right handle bar. From 2003 on, the turning on of the lights is controlled by the Ignitor Re: Power Tweak or Relay for Ignition Switch Relief - jul1us - 26-08-23 Does it make a big difference when installing? Re: Power Tweak or Relay for Ignition Switch Relief - b1k3rdude - 27-08-23 @jul1us Cleaned up post and linked in 'Gen1/2 Fazer 1000: Common maintenance & tasks' thread The other option as its now legal in the UK, is to swap out the headlight bulbs for LED. Re: Power Tweak or Relay for Ignition Switch Relief - unfazed - 27-08-23 (26-08-23, 01:19 PM)jul1us link Wrote: Does it make a big difference when installing?Probably not, but you would need to check and compare the 2001-2002 and the 2003 -2005 diagrams to be sure as there may be small differances. Be sure to get a relay with a diode in it and be aware they only work in one direction. The diagram has a 5 pin relay but a 4 pin one will do as long as it is rated 30amps |
