FZ6 dash gone, help needed - Printable Version
+--- Thread: FZ6 dash gone, help needed (/showthread.php?tid=83293)
FZ6 dash gone, help needed - CatalinU - 23-08-23
My dash is gone, nothing is displayed on the dash only the blue light is on. Will a S2 dash fit as a bolt on? Found that someone opened the dash and had to be cut apart to brake into
Re: FZ6 dash gone, help needed - agricola - 23-08-23
(23-08-23, 07:04 PM)CatalinU link Wrote: My dash is gone, nothing is displayed on the dash only the blue light is on. Will a S2 dash fit as a bolt on? Found that someone opened the dash and had to be cut apart to brake into
Try Breakers yards for a working direct replacement
Re: FZ6 dash gone, help needed - Grahamm - 23-08-23
It's possible that the LCD display has just come loose from the circuit board.
Check out this thread that might offer a solution:
https://foc-u.co.uk/index.php?topic=25376.msg29975o
As far as I know, the S2 dash is not a direct swap as the wiring has changed a little, but you can buy after-market versions.
