Clutch - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Clutch (/showthread.php?tid=83283) |
Clutch - fatbloke62 - 13-08-23 Hi foccers not posted for a while but I need some advice if possible, I've noticed of late when the bike is idling the clutch is silent, pull in the lever and it starts rattling ,something I have never had before any ideas ,cheers Re: Clutch - Gaz66 - 08-09-23 Hi.. Depends what u call a rattle, 1 mans rattle is another mans rumble. If it concerns u, it needs stripping for a bit of inspection. More than likely a wear issue, often the springs get weak in the clutch hub & rattle like crazy, this can affect most bike clutches, but could be the dreaded bung that detached from the shaft end, never seen it myself, but it does happen, I would have thought any foreign body rattling around in a clutch assembly would either lock the clutch up or stop it releasing. Spanners out time. :thumbup Re: Clutch - Gnasher - 12-09-23 If there is a noticeable rattle/rumble when the clutch is pulled, that would suggest basket bearing and/or worn basket. Could also be push rod assembly wear. Re: Clutch - b1k3rdude - 14-09-23 (12-09-23, 01:04 PM)Gnasher link Wrote: or worn basket.This is a common point of wear, that depending on the amount of wear can only be resolved by replacing the clutch basket with a new or less worn one. |
