Hyperpro spring - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Hyperpro spring (/showthread.php?tid=83186) |
Hyperpro spring - Ratters - 13-05-23 I’m considering replacing standard rear shock spring with a Hyperpro, the bikes done 51000 miles and I’m going to be carrying luggage on it too. The other option is the less favourable but potentially better YSS total rear shock replacement. Anyone out there with these mods can shine a light on? Also the forks , I’m going to change oil to 15w but is it worth putting in progressive springs too? Thanks for any help Re: Hyperpro spring - darrsi - 13-05-23 Not sure what springs I have in my forks, as a I bought a used pair years ago? But what I do know is that the 15w slightly heavier oil makes a very pleasant difference up front and is highly recommended. Re: Hyperpro spring - mtread - 13-05-23 I've got Hagon progressives and 15W. Much better than standard (in my opinion) Re: Hyperpro spring - Grahamm - 13-05-23 I have the FZ6 and replaced the fork springs with Hyperpro progressives and the rear with a YSS which has definitely improved the handling. My only issue is that Hyperpro supply 15W oil with the forks but as I only weigh 62kg that's too heavy for me, especially in cold weather (it's better when things warm up and it flows a bit more quickly), so I'm going to replace it with a lighter weight at some point. Re: Hyperpro spring - darrsi - 13-05-23 (13-05-23, 07:19 PM)mtread link Wrote: I've got Hagon progressives and 15W. Much better than standard (in my opinion) Did you try the 15w oil first, or change the springs at the same time? Re: Hyperpro spring - mtread - 13-05-23 Quote:Did you try the 15w oil first, or change the springs at the same time?Done (ages ago) together. I think I remember Hagon supply the oil as part of the kit. Put a Hagon rear on first, which improved the knackered back end enormously. So went for the front too. 25k miles later, both still good. Re: Hyperpro spring - darrsi - 14-05-23 (13-05-23, 10:30 AM)Ratters link Wrote: I’m considering replacing standard rear shock spring with a Hyperpro, the bikes done 51000 miles and I’m going to be carrying luggage on it too. The other option is the less favourable but potentially better YSS total rear shock replacement. Anyone out there with these mods can shine a light on? If i was you i would try the oil upgrade first, on its own, and see what you think as it may be enough for your needs. Re: Hyperpro spring - Frasier - 16-05-23 Proud owner of a rear YSS here. Highly recommended. Regarding the front: I know I'm spoiled with my several Öhlins equipped road and race bikes, but I would never do the good old "just progressive springs + thicker oil" treatment. This don't make the front "better", only stiffer. There are fork valves (emulators), could be installed with a little mechanical knowledge, and they're the best things (on the budget) what can happen to these damper rod forks. YSS have the proper sized fork valves for the FZS600. Forget progressive springs, put in linears, for your weight. Progressivity must be adjusted with oil level. My FZS on YSS suspension front and rear behaves very good on the road, plush, but don't collapses on hard braking or uneven tarmac. I was surprised how good it is. Recommend to put a cable tie on the right fork tube to check the fork travel. Happy tinkering! |
