Oil usage - maybe change the sump gasket ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Oil usage - maybe change the sump gasket ? (/showthread.php?tid=83149) |
Oil usage - maybe change the sump gasket ? - NorMorty - 06-04-23 Hello and a happy Easter from a snowy Norway.. My 99' fzs600 ( ca 281' km on the clock) been sittin in the shed since october so drain the oil etc now -but befor i refill I remember the oil usage problemo - add the ca 2dl oil fix every now&then ~ 2week to shutup the oil light ( except on downhill in right turn ) .. - engine's was qute "normal" just some bluesmokin for the first 2-5.. min when cold So my Q : Any point to just swap the sump gasket befor I refill ? (ebay'd from your splendid island some years ago )- its quite alot of (normal?) solidfy oil / gunk around the right lower of the bikes oil pan sump / gear change area Is it 'hard' to change the sump gasket meself / somthin to watch out for..? 1 off with the downpipe etc.. 2 .. -found this on yt : watch?v=zrW5j7CskRU but its for a fj1300.. Or mby should a garage do that job ? btw - Can it be done with just the sidestand down ( my left leg centerstand is curretly snapped off - guess that also need to be rewelded )Kind regds (& sorry for me bad egnlish :lol [size=78%] )[/size] morty Re: Oil usage - maybe change the sump gasket ? - unfazed - 07-04-23 Is it leaking from the sump gasket??? Oil needs to be slightly about the the level indicator as the oil level switch is very sensitive. These bikes hav a nikisil bore and any oil consumption is more often from the Valve stem seals than the Ring/Bore wear |
