swapped out the Fazers camshafts for ones from the thundercat today. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: swapped out the Fazers camshafts for ones from the thundercat today. (/showthread.php?tid=83145) |
swapped out the Fazers camshafts for ones from the thundercat today. - benzimo_ - 01-04-23 upon swapping the camshafts over, I had realised that the exhaust cam was advanced by 1 tooth lol. no wonder it sounded like it had a burble tune. rest assured all went well, if you are looking to do this then make sure you swap the camshaft sprockets over and that's it. also the timing is tricky as the timing marks are different but you can keep the original timing of the Fazer for low end.torque with a bit of oomph but timed for high end it will just zoom away. Sent from my Pixel 7 Pro using Tapatalk Re: swapped out the Fazers camshafts for ones from the thundercat today. - basher - 07-06-23 what year of thundercat cams are compatible with 98 fzs 600? Re: swapped out the Fazers camshafts for ones from the thundercat today. - benzimo_ - 07-06-23 (07-06-23, 06:19 PM)basher link Wrote: what year of thundercat cams are compatible with 98 fzs 600?any year. all the same. Sent from my Pixel 7 Pro using Tapatalk Re: swapped out the Fazers camshafts for ones from the thundercat today. - BBROWN1664 - 07-06-23 (01-04-23, 12:17 PM)benzimo_ link Wrote: you can keep the original timing of the Fazer for low end.torque with a bit of oomph but timed for high end it will just zoom away. did you dyno the bike before and after? Does it really make a difference or is it wishful thinking? Re: swapped out the Fazers camshafts for ones from the thundercat today. - benzimo_ - 07-06-23 (07-06-23, 08:09 PM)BBROWN1664 link Wrote: [quote author=benzimo_ link=topic=27663.msg331507#msg331507 date=1680347826] did you dyno the bike before and after? Does it really make a difference or is it wishful thinking? [/quote]no Dyno but it definitely tries to power wheelie like never before especially on 2nd and 3rd Sent from my Pixel 7 Pro using Tapatalk Re: swapped out the Fazers camshafts for ones from the thundercat today. - basher - 19-06-23 thinking about try this, how does one know what is the correct timing if the marks dont line up? thanks Re: swapped out the Fazers camshafts for ones from the thundercat today. - Mike_2002 - 21-06-23 I'm glad I saw this post, I have a pair of Thundercat cams, now just need to sort rest of bike out and see how it goes. Re: swapped out the Fazers camshafts for ones from the thundercat today. - benzimo_ - 21-06-23 I wouldn't mind removing the tank, side covers, battery, airbox, spark caps, carbs, head cover to show you what my timing looks like Sent from my Pixel 7 Pro using Tapatalk Re: swapped out the Fazers camshafts for ones from the thundercat today. - basher - 02-07-23 you could just remove the ht leads and the valve cover, you shouldnt need to remove everything, if you could I would greatly appreciate it as I am seriously considering it and the only thing holding me back is worry about the timing and the fact I dont know how its supposed to look with the thundercat cams. thanksĀ :thumbup Re: swapped out the Fazers camshafts for ones from the thundercat today. - benzimo_ - 02-07-23 (02-07-23, 09:39 PM)basher link Wrote: you could just remove the ht leads and the valve cover, you shouldnt need to remove everything, if you could I would greatly appreciate it as I am seriously considering it and the only thing holding me back is worry about the timing and the fact I dont know how its supposed to look with the thundercat cams. thanksĀ [emoji106]wel you would need the fuel tank off to get to the head cover bolts (which is unbolted in a Criss cross pattern starting from outwards and making your way inwards (but opposite direction when installing)) and you'll need the carbs pushed upwards (you don't need to remove the carbs, just undo the clamps and push it up) this is needed to get to the camchain tensioner. TL DR: fuel tank off for head bolt access and carbs pushed up for camchain tensioner access. I currently commute almost everyday to the airport since I'm a pilot in training which should finish in about 2 months so I could take pictures when that's all completed but let me check if I have some old pictures, I will check and upload them later if I find any Sent from my Pixel 7 Pro using Tapatalk Re: swapped out the Fazers camshafts for ones from the thundercat today. - basher - 03-07-23 curious why you need tensioner access? Re: swapped out the Fazers camshafts for ones from the thundercat today. - benzimo_ - 03-07-23 (03-07-23, 09:35 PM)basher link Wrote: curious why you need tensioner access?to be able to remove the old camshaft Sent from my Pixel 7 Pro using Tapatalk |
