Firing order on a 99 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Firing order on a 99 (/showthread.php?tid=83141) |
Firing order on a 99 - Lividcoconut - 28-03-23 hey all, hope some of you guys are getting some good weather, currently im trying to figure out why my bike is running rough, i think ive narrowed it down to needing new spark plug caps, but im also not sure if i have the ht leads going to the correct cylinders, i cant find any mention in the haynes book or this forum for what order the engine fires in AND which coil pack does which cylinder, any help would be much appreciated, many thanks in advance!! Re: Firing order on a 99 - unfazed - 29-03-23 1 and 4 are fed from the left coil and 2 and 3 from the right coil, looking at them as if you are sitting on the bike.Cylinders are 1, 2, 3, 4 again left to right for the position mentioned Re: Firing order on a 99 - BBROWN1664 - 29-03-23 :agree And the firing order is 1-3-4-2 Re: Firing order on a 99 - unfazed - 30-03-23 BB going on the valve clearances check it has to be 1-2-4-3 Check Cyl 1 with all valve closed rotate 180degrees cyl 2 all valves closed rotate 180 degrees cyl 4 all valves closed and finally rotate 180 and 3 all valves |
