3rd cylinder cold - blocked air passage ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 3rd cylinder cold - blocked air passage ? (/showthread.php?tid=83126) |
3rd cylinder cold - blocked air passage ? - siedlik - 08-03-23 Hello, There are 2 holes in front of the carb, is there a screw or jet that could be blocked? As the 3rd cylinder is cold at idle, but it's fine when going above 5000rpm. I did rebuild the carbs, but not sure if I've seen a screw in one of those holes. Will have to take the carbs out again :rolleyes https://youtu.be/I0siKsK6CfM?t=116 Just found a video and looks like that could be the issue. Thanks
Re: 3rd cylinder cold - blocked air passage ? - unfazed - 08-03-23 Would be highly unusual to have an air jet blocked unless you ran it with out an air filter or maybe placed the carbs on a dirty bench.I would double check the pilot jets and the air screw settings.The pilot jet do not have a clean hole but a web design internally and can be notoriously difficult to clean if badly clogged by old fuel lacquer Re: 3rd cylinder cold - blocked air passage ? - BBROWN1664 - 08-03-23 sounds like a blocked idle jet Re: 3rd cylinder cold - blocked air passage ? - siedlik - 09-03-23 Nothing looks blocked. Idle screw was about 3 turns before rebuild, but I decided to do 2,5 as in the manual. Would that make one cylinder not idle? Will try 3 turns and put the carbs back. Re: 3rd cylinder cold - blocked air passage ? - BBROWN1664 - 09-03-23 (09-03-23, 11:15 AM)siedlik link Wrote: Nothing looks blocked. Blocked idle jet - my money is on this still Poor connection on HT lead Re: 3rd cylinder cold - blocked air passage ? - unfazed - 09-03-23 Could you see through the pilot jet? Did you clean the carbs and jets in a Ultrasonic bath or by hand? If by hand, what did you clean them with? Re: 3rd cylinder cold - blocked air passage ? - siedlik - 10-03-23 I have compared the idle jet with others, and they are the same. I even swapped them. I have swapped HT leads with 2 and 3 cylinder, new spark plug, new cap plug. Still the same. So I got Compression, I got Spark, I think I only miss fuel on idle. The bikes run fine on a high rpms, its just that 3rd cylinder is not idling. The pilot jet screw on that 3rd cylinder was a bit higher when fully seated, maybe that could be an issue, I have added half turn more on that one and will test it today. Also next to a Pilot jet screw, there is something blanked off next to it. What's that? One one of the videos someone said to remove the blanks when cleaning. Re: 3rd cylinder cold - blocked air passage ? - unfazed - 10-03-23 It's a blank, used in other applications, but not the fazer.You may have a leaking float valve allowing to much fuel at tickover, O ring ma have hardened and become brittle. allowing fuel to bypass the needle jet. This is a common issue on the fazers as they are now 20 plus years old. Re: 3rd cylinder cold - blocked air passage ? - siedlik - 12-03-23 I have put the carbs back and they run pretty good, but after warm up they run a bit crap at idle. Tested the exhaust temps, and the exhaust 1st - 200C, 2nd - 200C, 3rd - 120C, 4th - 150C Could the coils go bad after warmup or something like that ? The bike runs fine at normal speed, but crap at idle. Tested the coils at cold, and they are in spec. Do the specs change when they are warmed up ? Would it be possible that just the right side of the coils goes bad after warmup? Will do more tests tomorrow and order new coils set. Re: 3rd cylinder cold - blocked air passage ? - BBROWN1664 - 12-03-23 the same coil does 1&4 and the same coil does 2&3 so a bad coil would affect its other cylinder too. Have you tried balancing the carbs? Re: 3rd cylinder cold - blocked air passage ? - siedlik - 12-03-23 I did balance the carbs. At the start the engine runs good, not perfect. Exahoust temps were 200, 200, 190, 160. But after a warmup idle goes bad and the temps go to 230, 230, 150, 100. The carbs cant go bad after a warmup, it has to be an electrical issue. I will replace the coils, hopefully, that will fix it. After a warmup, I think the resistance of the coils is going up and most of the sparks are going into the short leads with is cylinders 1 and 2. Re: 3rd cylinder cold - blocked air passage ? - siedlik - 15-03-23 (12-03-23, 05:48 PM)BBROWN1664 link Wrote: the same coil does 1&4 and the same coil does 2&3 so a bad coil would affect its other cylinder too. New coils fixed the issue, all temps are 230 now. |
