Nose cone & headlights - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Nose cone & headlights (/showthread.php?tid=83114) |
Nose cone & headlights - ArchDruid - 24-02-23 So, besides my modified Fazer, and FZR, and a YZF, I'm busy building another 'special'. Which of you knowledgeable & experienced people can tell me what the differences are between the fox eye versions of the 1000 and the 600. I'm looking to buy a nose cone, headlights & mounting bracket for a separate (non- Fazer) bike project. I was leaning towards the FZS 600 fox eye set, but have been offered one from a 1000. Question is mainly around the sizes..., not worried about mounting arrangements - those will be modded to suit anyway. Are the 1000 versions narrower than the 600 versions ?Any other arbitrary info would help... Thanks !! Re: Nose cone & headlights - Gaz66 - 27-02-23 Hi Pal. What info are u specifically looking for? If it's measurements of a 1000 nose cone, I can help with that, 1000 is defo a bigger unit than a 600, both look very similar from 20yards away but very different up close. Re: Nose cone & headlights - ArchDruid - 01-03-23 Width across the nose (widest point) would be helpful (for the 1000) Interesting to note that the headlights have the same part number for 600 & 1000 (5LV-8431000) And the cowl part numbers are similar, with only the model identifier being different 5RT-2835G-00-P2 v 5LV-2835G-00-P2 Thus the question 'whats different ?' particularly if considering the above & you understand the structure of the yamaha part number convention ... Cheers |
