throttle sticking - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: throttle sticking (/showthread.php?tid=82920) |
throttle sticking - dilboy - 13-07-22 Hi all Bike failed mot on throttle sticking, replaced the cables ,W.D the spring on the carbs Still sticking. any ideas amigos ? Re: throttle sticking - FazThou - 13-07-22 Are they routed correctly ? Does the throttle feel free on the bars ? Re: throttle sticking - unfazed - 16-07-22 Could be corrosion of the butterfly shaft. Not easy to lubricate unless you remove the carbs. I have seen it on a few fazers, especially ones that are out in all weathers and used all year round Re: throttle sticking - BBROWN1664 - 16-07-22 disconnect the cables and determine if the problem is with the carbs or the cables/grip Have to fitted heated grips? Are the fowling the switch assembly? Is the bar end weight catching on the end of the grip? |
