Carb issues - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Carb issues (/showthread.php?tid=82801) |
Carb issues - dilboy - 16-04-22 Hi all So I've re connected my fuel tank to the carbs ,turned the bike over ,then petrol starts flowing out of an overflow pipe on the carbs. [size=78%]all the pipes are on correctly[/size] Any ideas what to look for. cheers Re: Carb issues - BBROWN1664 - 16-04-22 a stuck float. try giving the bowl a good tap Re: Carb issues - Trinafzs - 20-04-22 Is it possible to remove a carb float bowl without removing the carbs in full? I have a similar problem with petrol pouring from one carb and the others seemingly working as required! Re: Carb issues - BBROWN1664 - 20-04-22 it is, but its not easy. Putting the bugger back on again is even harder Re: Carb issues - Sherb68 - 23-04-22 Hi i had a similar problem with my carbs,after removing umpteen times and still leaking fuel i found the problem to be the seals on the link pipes inbetween the carbs hope this helps |
