changing air filter - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: changing air filter (/showthread.php?tid=82775) |
changing air filter - butthead - 28-02-22 Hi all, the haynes manual says to remove the fuel tank in the process of changing the air filter , do you have to completely remove it ? or if you lift up the tank on its rear hinge and support it as upright as possible can you change filter without complete removal ? as a secondary question is there any noticeable difference to say K&N over OEM filters apart from money ? Re: changing air filter - Grahamm - 28-02-22 On my FZ6, it's enough to raise the front of the tank and prop it up. Also, frankly, unless you're going to be racing, most people aren't ever going to notice the difference between different filters (personally I use HiFlo brand which work fine and are a lot cheaper). Theoretically, IIRC K&N filters are reusable, so you might eventually save money in the long run, but that doesn't count the time spent reoiling them... Re: changing air filter - darrsi - 28-02-22 I noticed a difference immediately when I put my K&N filter on. Nothing to do with power, just more responsive on the throttle. I clean it once a year using warm water and washing detergent powder, let it dry naturally on a warm sunny day, then lightly oil it with the proper K&N Oil Spray. I'm still on my first can of spray and had the filter for a few years now, so not expensive at all. And it will be the last filter you ever buy for the bike. Re: changing air filter - BBROWN1664 - 28-02-22 (28-02-22, 12:18 PM)butthead link Wrote: Hi all, the haynes manual says to remove the fuel tank in the process of changing the air filter , do you have to completely remove it ? or if you lift up the tank on its rear hinge and support it as upright as possible can you change filter without complete removal ? On the FZS600 you dont have to remove the tank, but its easier if you do. It is the back of the tank that gets in the way when trying to remove the rubber cover above the airbox. Re: changing air filter - butthead - 28-02-22 yes mines the fzs600 box eye 2001, saw a you tube video on the later 2003 variant , he removed the tank but wasnt sure if the set up was identical to mine , i know what you mean now by the flexi cover and it would be made awkward leaving the tank on thanks everyone Re: changing air filter - midden - 05-03-22 (28-02-22, 01:25 PM)darrsi link Wrote: I noticed a difference immediately when I put my K&N filter on. Nothing to do with power, just more responsive on the throttle. I went K&N mainly to save hassle of changing it every year or sooner. 45k miles of untouched use is great
