Ignition light - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Ignition light (/showthread.php?tid=82754) |
Ignition light - festerbestertester - 26-01-22 Start and set off on the bike no problem. After about a mile red light comes on. Parked up for 10 minutes back to normal. This is happened several times this week, and wondering if this is a rectifier problem Re: Ignition light - Grahamm - 26-01-22 Get a multi-meter and check the output of the reg/rec and alternator according to the correct values in the manual. If they are ok, check the loom for damaged wires. Note that a faulty alternator or reg/rec can kill a battery
Re: Ignition light - festerbestertester - 26-01-22 Will do thanks Re: Ignition light - unfazed - 26-01-22 Is it the red light in the Tacho of the red light for the oil? does the speedo and rev counter drop to zero? Re: Ignition light - BBROWN1664 - 27-01-22 red light on the FZS600 is for oil level - check the oil Re: Ignition light - darrsi - 27-01-22 Put the bike on level ground on the centre stand, start the bike and let it run for a minute. Switch off, then let the oil settle, that will be the oil level. Sounds like the oil is too low. Re: Ignition light - festerbestertester - 27-01-22 Oil ok Re: Ignition light - BBROWN1664 - 27-01-22 try putting a little more in. The sensor is sensitive. Re: Ignition light - festerbestertester - 28-01-22 Just had a thought. The oil light comes on when I switch the ignition on but goes out Before I pressed the starter. Re: Ignition light - BBROWN1664 - 28-01-22 The oil light should come on when you press the starter button (its the self test) but go out when you release teh button. If the light comes on any other time it is telling you the oil level is too low. Put a touch more oil in. Re: Ignition light - festerbestertester - 28-01-22 Just comes on briefly when ignition is switched off and then goes out. Not on when I press starter. Re: Ignition light - TOM VR46 - 29-01-22 Would agree with above, needs a wee top up of oil. My oil light used to come on if i gave it a wee bit too much throttle from the off, but went out a couple of miles down the road. A wee top up and oil light stays off. Sometimes an oil change can help if topping up dose not help. If you do as darrsi explained you will probably see oil level in check window about half of window. So wee top up and see how it goes. Re: Ignition light - festerbestertester - 29-01-22 Was planning to do oil and filter next week. Will see what happens. Re: Ignition light - festerbestertester - 02-02-22 Oil and filter changed, problem solved. Re: Ignition light - darrsi - 03-02-22 Sorted :thumbup |
