Valve clearance re shim or leave - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Valve clearance re shim or leave (/showthread.php?tid=82639) |
Valve clearance re shim or leave - Slippy - 03-10-21 Just checked my clearances in my 2003 fazer has 27k miles on it. All the clearances are in tolerance but only just. All my inlets are .11-.12 and exhausts are .21-.22. Question is should I leave this as it is or go get it re shimmed so they sit on the upper end of tolerance as they get tighter with age! Thanks in advance Re: Valve clearance re shim or leave - unfazed - 03-10-21 If they are all that good and the feeler guage slides in and out easily I would leave them and check them again a 40000 miles |
