Rev counter - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rev counter (/showthread.php?tid=82552) |
Rev counter - Don71uk - 29-07-21 Hi, looking for advice. 2001, FZS1000 Fazer, 89k on the clock and based the UK. Been out riding for two days, first day ok, second day the tacho-Rev counter shows the revs, but suddenly drops to zero, engine all ok still running, then after a few seconds tacho Rev counter back to normal. This does not happen all the time, occurred about 10 times in a fifty mile ride. Nno other tacho Rev counter error codes, like the 3k , 7k etc. Speedo, lights, turn signals, neutral lights all working, clock keeping time, mileage working ok. Any ideas? Before I start pulling things apart, thanks, Don. [cleaned up the html - bkd] Re: Rev counter - FazThou - 29-07-21 You could check the big white connector under the left fairing infil as these are prone to corrosion Pull the connector apart and spray some contact cleaner in both sides and see if there is any difference Re: Rev counter - Don71uk - 29-07-21 Yer, I did think about that, so tomorrow I’ll have look. Re: Rev counter - Gnasher - 29-07-21 Check the EXUP valve, I know the manual states it should jump from 0 - 7k and back to engine rpm then 3 secs and 0 - 7k etc but they don't always. The usual suspect is the EXUP valve sticking, start there. Re: Rev counter - Don71uk - 02-08-21 Looked at the white connector a little bit of white oxide on the contacts so cleared with contact cleaner, and re connected. Short 40 miles and all appears to be ok, Only time will tell. Exup all ok. Re: Rev counter - Gnasher - 02-08-21 (02-08-21, 05:54 PM)Don71uk link Wrote: Looked at the white connector a little bit of white oxide on the contacts so cleared with contact cleaner, and re connected. Yep, that will give you the same behaviour. (02-08-21, 05:54 PM)Don71uk link Wrote: Exup all ok. :thumbup Re: Rev counter - FazThou - 02-08-21 (02-08-21, 05:54 PM)Don71uk link Wrote: Looked at the white connector a little bit of white oxide on the contacts so cleared with contact cleaner, and re connected. Short 40 miles and all appears to be ok, :thumbup :thumbup :thumbup Re: Rev counter - Don71uk - 23-09-21 Update, problem still exists, cut out the white connector and joined the wires soldering in new sections, but the tacho is still jumping around. I have noticed that when the riding the engine sometimes feels a bit woolly, as if there is a lack of power or someone has touched the brakes, the bike does not slow down, there is no misfire pops bangs and it only lasts for a second or two then eventhing is back to normal. It feels if it is electrical rather than mechanical if you know what I mean. any ideas? Re: Rev counter - unfazed - 23-09-21 Test your TPS with a meter, they can go a bit off internally. You need to test it carefully with a Meter, the resistance should move smoothly up through the range with no jumping from. If there is any doubt change it. The one from the DR400 fits and is usually half the price of the Yamaha one. You will need to swap a wire in the plug and I posted a "How to" int the downloads section. Yamaha Part Number is 4XY–85885–00 and compatible Suzuki Part Number is 13580-21F00 https://foc-u.co.uk/index.php?action=downloads;sa=view;down=65 Re: Rev counter - Don71uk - 02-11-21 Been a while, but I think the problem is fixed. Thanks to unfazed who mention that the TPS can go off, well on checking mine it was completely wanked., the readings both for the static test were higher that should be, and the test when you twist the throttle we’re all over the space, jumping from anything from 3 to 18 k ohms. So looked for a TPS on eBay but nothing apart from one in Germany £120 plus postage, unknown make, so I bit the bullet and got an OEM one from Fowler’s £150 delivered. All fitted and have had a couple of rides now, the tacho is behaving itself, but the biggest difference is that the bike, now at nearly 90,000 miles feels like a new bike, the throttle pickup is so smooth, guess the TPS has been on the way out for sometime. Thanks for the advice, Don.
Re: Rev counter - FazThou - 02-11-21 Glad you got it sorted mate Shame you had to buy a brand new one but at least it will last for a good while Re: Rev counter - Don71uk - 02-11-21 Hope so, not bad for a 20 year old bike. Re: Rev counter - teecee90 - 04-11-21 I managed to pick up and OEM TPS for £30 on Ebay a few months ago. It sits in my spare parts tin....
Re: Rev counter - Don71uk - 04-11-21 Nothing when I looked on eBay, Fowler’s only have 2 left now, csml the Dutch parts company don’t have any. Re: Rev counter - NitramA - 04-11-21 I assume that the TPS is different between the FZS and FZ1? There are a couple on eBay at a reasonable price Re: Rev counter - Don71uk - 04-11-21 Yes different |
