White power shock help/user manual anyone? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: White power shock help/user manual anyone? (/showthread.php?tid=82411) |
White power shock help/user manual anyone? - Yas1 - 12-05-21 Hi All, I just bought an FZS1000 which has a white power shock fitted. I can see there are 3 adjusters which I'm guessing are low and high rate compression, at the top, and rebound at the bottom, but I was hoping someone might have a user manual to clarify things for me please? I can't see any markings on the shock to indicate what model it is or which adjuster is which. Any help appreciated! Thanks in advance, Karl Re: White power shock help/user manual anyone? - robbo - 12-05-21 WP are owned by KTM. Maybe one of their dealerships could help you out with info. Re: White power shock help/user manual anyone? - Gnasher - 12-05-21 Generally Rebound is at the top and compression is at the bottom, that said some shock applications/manufactures fit the shock upside down. Basic shocks have no damping adjustment just pring preload, next comes those that have either just compression or compression and rebound and redound, lastly H/L compression damping and remote preload. It is also possible to get remote preload on some manufactures whole range and if you've got H/L damping it's usually for both compression & rebound. Some WP shocks use a black dial/ring that you turn at the bottom blow the spring mount. Look herehttps://www.wp-suspension.com/en-us/manuals/ Re: White power shock help/user manual anyone? - Yas1 - 12-05-21 Thanks Guys, unfortunately I can't see any model information so I can't use the WP website. The shock has 3 adjusters, 2 top and 1 bottom which I'm assuming will be low and high rate compression (top) and rebound at the bottom. I'd like to know the recommended base settings for the shock so I can work from there. I think my next option is to call a WP specialist. I fitted a second hand Ohlins to an xr400 and had fantastic support from one of their dealers Re: White power shock help/user manual anyone? - Timbo - 13-05-21 (12-05-21, 03:17 PM)Yas1 link Wrote: Thanks Guys, unfortunately I can't see any model information so I can't use the WP website. Your start point will be in the middle of the range. Thereafter test ride and adjust one at a time. Lots of info on the web, its quite easy to setup yourself |
