fuel gauge fault - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: fuel gauge fault (/showthread.php?tid=82315) |
fuel gauge fault - butthead - 01-04-21 my fuel guage is not reading correctly only just happened last ride , filled up to the brim yet the fuel gauge only read half way, after about 100 miles it then read near empty then orange fuel warning light came on , so im possibly thinking sender unit faulty ? anyone had this issue before ? also if it is sender unit where is that located , underside of the tank i guess ? TIA Re: fuel gauge fault - BBROWN1664 - 01-04-21 its in the bottom of the tank. Lift the tank and make sure the electrical connection is good first. High resistance will show and empty tank. Re: fuel gauge fault - Disorderlypunk - 01-04-21 (01-04-21, 10:37 AM)BBROWN1664 link Wrote: its in the bottom of the tank.exactly what i was gonna say, make sure all the connectors are clean, sometimes even just disconnecting and reconnecting can fix problems. a can of electrical contact cleaner is a handy thing to have laying around Re: fuel gauge fault - butthead - 01-04-21 cheers guys , ill give that a go first , see if it cures it . thank Re: fuel gauge fault - unfazed - 02-04-21 Ever think of checking the downloads section :rolleyes Re: fuel gauge fault - butthead - 04-04-21 well it exactly what you guys said , green corrosion in the sender multiplug , quick scrub up and a squib with WD and its all back to 100% now , cheers guys :thumbup Re: fuel gauge fault - Jules-C - 05-04-21 ? |
