Hazard lights come on when ignition switched on. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Hazard lights come on when ignition switched on. (/showthread.php?tid=82106) |
Hazard lights come on when ignition switched on. - festerbestertester - 09-11-20 I have just changed the clutch and when I switched my ignition on the hazard lights came on and would not switch off. Any help much appreciated. Re: Hazard lights come on when ignition switched on. - Disorderlypunk - 09-11-20 if thats all you have done then i would say you have nipped some wires within the switch cluster causing a short. Re: Hazard lights come on when ignition switched on. - festerbestertester - 09-11-20 Dark now. Will check in morning. Thanks Re: Hazard lights come on when ignition switched on. - festerbestertester - 10-11-20 Short! Fixed. |
