Oil Level Light (5DM) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Oil Level Light (5DM) (/showthread.php?tid=82092) |
Oil Level Light (5DM) - Billbott - 29-10-20 I have an issue with my oil level light on my 1999 5DM: When I switch on the ignition, the handbook says that it should be on, going off when started up – a self test. The only light I see when I switch it on is the neutral light. I have checked the bulb and its ok (swapped it with the known working neutral light) My concern is it wont come on when it needs to (low oil level) Has anyone else come across this / fixed it? Re: Oil Level Light (5DM) - Gnasher - 29-10-20 Check the connections at the switch, they are prone to corrosion, often just a clean up will do
Re: Oil Level Light (5DM) - Billbott - 29-10-20 (29-10-20, 02:08 PM)Gnasher link Wrote: Check the connections at the switch, they are prone to corrosion, often just a clean up will do Brill - where is the switch located please? Re: Oil Level Light (5DM) - Gnasher - 29-10-20 In the sump pan, left hand side of the engine below and in front sprocket, it's the only thing with wires coming out of it
Re: Oil Level Light (5DM) - Billbott - 29-10-20 (29-10-20, 03:02 PM)Gnasher link Wrote: In the sump pan, left hand side of the engine below and in front sprocket, it's the only thing with wires coming out of itThanks, will try it later. Same place as the one on my GPZ900
Re: Oil Level Light (5DM) - BBROWN1664 - 29-10-20 it only lights up when the starter button is pressed. To test it, turn off the kil switch and press the starter. Re: Oil Level Light (5DM) - Billbott - 29-10-20 (29-10-20, 03:27 PM)BBROWN1664 link Wrote: it only lights up when the starter button is pressed. To test it, turn off the kil switch and press the starter. Yeah, tried that, still didn't work.
Re: Oil Level Light (5DM) - BBROWN1664 - 29-10-20 (29-10-20, 03:30 PM)Billbott link Wrote: [quote author=BBROWN1664 link=topic=26585.msg320939#msg320939 date=1603981660]I would suggest the bulb is the fault here then but as you have changed that, look at the wiring. The self test, does not test the switch, just the bulb. Yeah, tried that, still didn't work. [/quote] Re: Oil Level Light (5DM) - MikeBike - 29-10-20 Well if you still have the issue, and until you fix it, you can always have a regular check on the oil level. I have my own since 2018 and I have no issues of oil consumption. So a regular check should prevent you from bigger issues. Re: Oil Level Light (5DM) - Billbott - 30-10-20 Wiring 'seems' ok, nothing out of the ordinary. Switch connections also seem good... MikeBike, indeed - I don't have an oil level check light on any of the others (except my Lc) - I would just prefer to have everything working. Re: Oil Level Light (5DM) - Gnasher - 30-10-20 If your sure the connections are both tight and corrosion free, the bulb if working check the wiring continuity and test the switch, as it's possible the wiring has broken/sorted and corrosion has penetrated into the switch. Its a very simple system, it will be one or a couple of the above. Re: Oil Level Light (5DM) - Billbott - 30-10-20 (30-10-20, 09:39 AM)Gnasher link Wrote: If your sure the connections are both tight and corrosion free, the bulb if working check the wiring continuity and test the switch, as it's possible the wiring has broken/sorted and corrosion has penetrated into the switch. Its a very simple system, it will be one or a couple of the above. Will do, thanks for the info
Re: Oil Level Light (5DM) - fazersharp - 30-10-20 This is the info in my 98 booklet |
