Uneven brake pad wear - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Uneven brake pad wear (/showthread.php?tid=82025) Pages:
Uneven brake pad wear - bigfootpete - 19-09-20 Does uneven brake pad wear indicate an issue with my wheel? Long time no hear! It's been a few years since I was last on here... I took my bike in to the Yammy stealer for a puncture repair (turns out it was just the valves), when I set off I immediately noticed a rubbing sound from the front, took it back and they said it was the front wheel bearing. I've just checked for play and the wheel is solid. So I took the brake calipers off (they were a bit sticky), and the front left(facing the bike) has almost worn out the inside pad. The right side pads are pretty even, if slightly more worn on the inside. But it's a bit odd to have just one pad worn out - does that indicate some other issue? And does anyone recommend some replacement pads? Re: Uneven brake pad wear - tex - 19-09-20 Sounds like the pistons are sticky or seized, give them a good clean and a smear of red rubber grease Re: Uneven brake pad wear - b1k3rdude - 19-09-20 (19-09-20, 12:33 PM)bigfootpete link Wrote:
Re: Uneven brake pad wear - b1k3rdude - 19-09-20 Oh and the rubbing sound is the metal backing material of one of the pads rubbing against the disc, better replace the pads now before you start doing damage to the disc/s. And Welcome back fella. Re: Uneven brake pad wear - bigfootpete - 19-09-20 (19-09-20, 05:32 PM)b1k3rdude link Wrote: Oh and the rubbing sound is the metal backing material of one of the pads rubbing against the disc, better replace the pads now before you start doing damage to the disc/s. Thanks man! I'd be on more often if the site wasn't blocked by work, as I rarely switch my pc on after work. I'll check out the pistons, the dealer is the same one who passed my MOT when the tyre pressures were about 20psi :eek Re: Uneven brake pad wear - b1k3rdude - 19-09-20 (19-09-20, 06:22 PM)bigfootpete link Wrote:
Re: Uneven brake pad wear - bigfootpete - 20-09-20 Ahhh, just had a check for other motorcycle places around - found one just around the corner that I didn't know was there, independent and very good reviews. Last place I went to for immobiliser installation I had to catch a taxi back as they didn't have the insurance to lend me a bike. Re: Uneven brake pad wear - b1k3rdude - 20-09-20 (20-09-20, 12:57 PM)bigfootpete link Wrote: Last place I went to for immobiliser installation I had to catch a taxi back as they didn't have the insurance to lend me a bike.They don't need insurance, :groan as long as you have a policy that allows to you ride other bikes your good to go. Re: Uneven brake pad wear - bigfootpete - 21-09-20 Well that was the excuse they gave me. I haven't been able to find anything on SBK brake pads? Did you mean SBS? Re: Uneven brake pad wear - bigfootpete - 21-09-20 Actually I found the post - SBS it is. Re: Uneven brake pad wear - Gnasher - 21-09-20 (21-09-20, 03:15 PM)bigfootpete link Wrote: Well that was the excuse they gave me. He did
Re: Uneven brake pad wear - Gnasher - 21-09-20 When they stick it's not always just a simple matter of freeing the off with a little grease. Every piston should be as free and I mean free one finger easy push in anymore and they will stick again. Water/moisture gets under the dust and sometimes the main seal, which will oxidise and swell, this places pressure on the seal which in turn makes the pistons stick. Often the only way is to strip the caliper and clean out the rebate/s. Re: Uneven brake pad wear - bigfootpete - 21-09-20 I only checked the left side, all the pistons were solid as a rock! Definitely needs some cleaning. Re: Uneven brake pad wear - b1k3rdude - 21-09-20 (21-09-20, 03:58 PM)Gnasher link Wrote: Often the only way is to strip the caliper and clean out the rebate/s.+1 Re: Uneven brake pad wear - VNA - 22-09-20 Quote:Quote from: bigfootpete on 20 September 2020, 12:57:15 PM Quote:They don't need insurance, :groan as long as you have a policy that allows to you ride other bikes your good to go. Most, but not all, insurance policies allow you to ride other private bikes that do not belong to you with the owners permission and as long as the bike has a valid private insurance policy on it. The vast majority of policies (as far as I am aware) will not allow you to ride bikes owned by commercial businesses. And if you are taking a courtesy bike, remember it is your legal responsibility to ensure that you are suitably insured. Make sure their policy is comprehensive and check the excess. Re: Uneven brake pad wear - bigfootpete - 30-09-20 Ok, after the last independent mechanic told me it was going to be expensive to sort out my stuck pistons (I heard, "I don't want to do it mate"). I gave it a whirl myself - the left side I managed to free up but they are still reluctant to move but they do move. On the right side they move freely but the problem I have is that I can't get them to stay down. So I put the new brake pads in, but the pistons force them together so I can't put the calliper back on the disc. Any ideas? Re: Uneven brake pad wear - Dudeofrude - 30-09-20 (30-09-20, 02:38 PM)bigfootpete link Wrote: Ok, after the last independent mechanic told me it was going to be expensive to sort out my stuck pistons (I heard, "I don't want to do it mate"). What do you mean you can't get them to stay down? Do you mean they come out on their own when you push them back? If so then take off the brake fluid reservoir lid before you push them back, that will let the excess air out ? just make sure to out it back on before squeezing the lever again haha Re: Uneven brake pad wear - Gnasher - 30-09-20 (30-09-20, 02:38 PM)bigfootpete link Wrote: Ok, after the last independent mechanic told me it was going to be expensive to sort out my stuck pistons (I heard, "I don't want to do it mate"). Mate I'm not being funny here, but it appears you're out of your depth here. Things are easy...... when you know how! The internet is full is people (Utube) and this forum offering advice, mostly for the right reasons, e.g. trying to help a follow biker etc. Which is fine, if you've not got sufficient experience and know how, to follow what appears to them simple, it just isn't that simple. They're many pro mechanics out there who will sort out your calipers. As for cost it really depends on what state they're in and what if any parts need replacing and that is what can make it expensive. Re: Uneven brake pad wear - bigfootpete - 30-09-20 (30-09-20, 02:45 PM)Dudeofrude link Wrote: [quote author=bigfootpete link=topic=26518.msg320336#msg320336 date=1601473098] What do you mean you can't get them to stay down? Do you mean they come out on their own when you push them back? If so then take off the brake fluid reservoir lid before you push them back, that will let the excess air out ? just make sure to out it back on before squeezing the lever again haha [/quote] Yep, that's what I meant, I'll give it a try thanks. Didn't want to go down the removal of the brake line from the calliper as then it gets messy. @Gnasher I'm no expert but I'm not going to ride it unless I'm 100% sure I've done the job properly and then tested them. Re: Uneven brake pad wear - bigfootpete - 30-09-20 That worked, thanks Dude, push test passed, I'll try to do a proper test tomorrow. |
