Fazer gen 1 float needle seat o ring - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fazer gen 1 float needle seat o ring (/showthread.php?tid=82008) |
Fazer gen 1 float needle seat o ring - Johnrambo20 - 09-09-20 is there anywhere in the uk or Europe where I can just buy the float needle seat o ring want to change them without buying a full kit if any body has brought them plz advise me where I can buy them thanks Re: Fazer gen 1 float needle seat o ring - b1k3rdude - 09-09-20 Are you refering tp part 7. from the following list..? https://www.fowlersparts.co.uk/parts/4189107/fzs1000-1c28-2005-050-b/carburetor Have you had a look online for an oring kit - https://www.amazon.co.uk/Rubber-O-Rings/s?k=Rubber+O+Rings Bear in mind you will need to check the rubber used is impervious to petrol. Re: Fazer gen 1 float needle seat o ring - FILZ6 - 09-09-20 Measure the inside diameter, and the cross section, then look on e bay for that size “o” ring. You may have to buy 10, that’s more than you need but far cheaper than carb kits. Look out for ethanol resistant material. I have done it this way on a cbr600 and a bandit 1200 pilot jets in the past. Hope this helps. Re: Fazer gen 1 float needle seat o ring - Johnrambo20 - 09-09-20 In the exploded diagram it’s part of pic 18 I’ve got o rings but need the o ring that’s suitable for petrol not water Re: Fazer gen 1 float needle seat o ring - Trebus - 09-09-20 http://foc-u.co.uk/index.php?topic=24659.25 ? Re: Fazer gen 1 float needle seat o ring - Johnrambo20 - 09-09-20 So quick update after doing some research which o rings can be use with petrol found them on eBay same as the ones that are listed on pats ivans kit Installation Site The one on his site r in USA and they won’t ship to uk but I’ve matched them on eBay if any body needs them they r 1.5mm cross section x 7.5mm inner diameter 10.5 mm outer diameter pack 100 £6.41 https://www.ebay.co.uk/itm/133276294777 Re: Fazer gen 1 float needle seat o ring - ArchDruid - 09-09-20 try nrp-carbs.co.uk I've bought bits & pieces there before, can't remember what tho ... Maybe not always listed on the website, so best to pick up the phone and chat to them. Always been helpful with me that way. |
