2007 FZ1 will no start - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: 2007 FZ1 will no start (/showthread.php?tid=81978) |
2007 FZ1 will no start - Budthewiser - 23-08-20 The rebuild on the FZ1 is nearly finished, i tried to start it yestersay but it wown't start. The pump primes but the nothing, not even trying to turn over. When i try and start it, the engine light comes on, Any ideas. Loose wire fuses side stand? Re: 2007 FZ1 will no start - Dudeofrude - 23-08-20 Have you looked at the diagnostic menu to see if its shows any error codes? Thats usually a good indicator of any problems Also check the obvious things, kill switch, battery or for instance I thought mine was knackered the other week when it was doing the same as yours, but turned out I'd left it in gear when I turned it off which then stops the starter kicking in ?? was both embarrassed and relieved at the same time haha Re: 2007 FZ1 will no start - Gnasher - 23-08-20 :agree Re: 2007 FZ1 will no start - Budthewiser - 23-08-20 Got it going, loose wire under the seat, I just disconnected and reconnected everything and ...BOOOM ...shes firing on all 4. Still waiting on handle bars, front left indicator and crash bobbins and shes finished. Thanks lads. Re: 2007 FZ1 will no start - b1k3rdude - 24-08-20 Ah that sound like corrosion on one or more of the pins then, if you can it would be a good idea to get inand clean them if you can, otherwise liberly spray WD40 into both parts of the connector and unplug-plug a few times. Got a pic of the connector btw, Im curious to see which one it is... Re: 2007 FZ1 will no start - Budthewiser - 29-08-20 I'll have a look but it wownt start now, j think it's the fuel pump relay. The connectors looked ok on the startef relay. Re: 2007 FZ1 will no start - Budthewiser - 31-08-20 (29-08-20, 01:26 PM)Budthewiser link Wrote: I'll have a look but it wownt start now, j think it's the fuel pump relay. The connectors looked ok on the startef relay. |
