'LEDGear' gear indicator - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 'LEDGear' gear indicator (/showthread.php?tid=81964) |
'LEDGear' gear indicator - Cagey_Thoughts - 20-08-20 Anyone remember these??? I have (had) one on my fazer... but the display is dropping some segments and the sender in place of the neutral switch has seen better days..... pity they are no longer available... was a great product... Re: 'LEDGear' gear indicator - mobile mouse - 20-08-20 Hi, I have one and mine did the same dropped LED segments. I found that you need to find the box under the tank the two cables connect into. Take out the display cable and clean the connector. The pins starts to corrode and each pin is a segment on the display. Re: 'LEDGear' gear indicator - Cagey_Thoughts - 20-08-20 Cheer MM ... I will give that a go....
Re: 'LEDGear' gear indicator - Middy2000 - 22-08-20 I've fitted a 'modern' Chinese style one. I mainly wanted it to stop me going for 7th gear. It works really well and the only downside I would say is it doesn't display the gear when stationary. For 30 quid I can't complain and fitting is straightforward. Re: 'LEDGear' gear indicator - Dudeofrude - 22-08-20 (22-08-20, 05:51 PM)Middy2000 link Wrote: I've fitted a 'modern' Chinese style one. I mainly wanted it to stop me going for 7th gear. Forgive my simple thoughts but surely if your stationary then your either in N (little green light) or 1st (No little green light)? ?? Re: 'LEDGear' gear indicator - NJD - 23-08-20 (22-08-20, 10:59 PM)Dudeofrude link Wrote: Forgive my simple thoughts but surely if your stationary then your either in N (little green light) or 1st (No little green light)? ?? Might mean that it works off some sort of drive (ie: constantly on the move for display to be shown) and therefore you can't tell if you've stopped in 2nd etc, but agree with your comment.
Re: 'LEDGear' gear indicator - Middy2000 - 23-08-20 Yes it picks up the feed from the Camshaft sensor. So not moving = no signal. It's when you come to a stop and not sure if you've gone into first or left it in second. The neutral light helps but how many of us have bikes that like to skip neutral. Re: 'LEDGear' gear indicator - Steve3351 - 24-08-20 (22-08-20, 05:51 PM)Middy2000 link Wrote: I've fitted a 'modern' Chinese style one. I mainly wanted it to stop me going for 7th gear. Hi Middy Where did u get the thing...? it's something I want to have but the ones I read about sounded too complicated to fit... your one sounds simple enough to fit. I'm constantly forgetting which gear I'm in.... Not so much the 1st or 2nd problem...my bike gives a distinctive crunch going into 2nd! Re: 'LEDGear' gear indicator - Middy2000 - 28-08-20 https://a.aliexpress.com/_BTKszE It's a doddle to fit. Plug and play in the connection box under the tank. Two wires - one to pick up an ignition feed. The other picks up the camshaft sensor which is accessible behind the seat lock panel. Identifying the correct colour wire can be the issue. It's referred to as grey or white but it's actually yellow Re: 'LEDGear' gear indicator - Cagey_Thoughts - 10-11-20 In the end I fitted a GTP .... LCD screen version... its ok.. fitted OK.. looks nice... but it no where near as accurate as the Healtech on the FJR.... THE GTP seems to need about 3k rpm to register the correct gear.... ive tried resetting it several times at low rpm.... but to no avail.... not a major problem... the bike is used for fun now... no commuting.. Re: 'LEDGear' gear indicator - Middy2000 - 17-11-20 That sounds about right in terms of the revs to get it to register. |
