Arrrrrrr bike is dead,help - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Arrrrrrr bike is dead,help (/showthread.php?tid=81935) |
Arrrrrrr bike is dead,help - dilboy - 06-08-20 Hello all Turn key nothing Battery fully charged,all fuses ok,all connectors connected Anything else I can check ? Cheers Re: Arrrrrrr bike is dead,help - Gnasher - 06-08-20 Starter rely, would be a good place to start. Half my post got deleted Arrrrr :rolleyes If it's clicking, check the side stand and clutch switches, if no joy with any of that come back. BBrown has now mentioned some of the above
Re: Arrrrrrr bike is dead,help - BBROWN1664 - 06-08-20 No lights at all or not turning over? If no lights at all then it has to be the battery (have you tested it with a meter to check 12v?) or the main fuse. If you have the neutral light, press the starter button and the dash lights up like a Christmas tree, then check the kill switch is on. If the dash doesnt light up like its Christmas, pull in the clutch lever and put the side stand up before hitting th estart button again. Re: Arrrrrrr bike is dead,help - dilboy - 06-08-20 Battery fully charged No click,or dash lightning up Will check starter motor Cheers Re: Arrrrrrr bike is dead,help - Gnasher - 06-08-20 (06-08-20, 06:44 PM)dilboy link Wrote: Will check starter motor It's the starter rely not the motor you need to check. What have you done to the bike since you last used it, or was it fine last it was used? Re: Arrrrrrr bike is dead,help - dilboy - 06-08-20 It was ok But sluggish,so removed carbs,cleaned and put back in Re: Arrrrrrr bike is dead,help - BBROWN1664 - 06-08-20 You say the battery is fully charged, have you checked the voltage? If your getting no lights, it wont be the starter motor or solenoid normally. Start by checking the basics. Battery was removed to remove the carbs. Did you put it back in the right way round? IS it really charged? Are the connections on properly? Have you dislodged the fuse? Re: Arrrrrrr bike is dead,help - dilboy - 09-08-20 Battery ok Power going into starter solenoid but now power going out,so ordering new one,hope that's it Cheers Re: Arrrrrrr bike is dead,help - BBROWN1664 - 09-08-20 have you checked the starter button actually works before plumping for the relay? Re: Arrrrrrr bike is dead,help - Disorderlypunk - 09-08-20 ive got a wierd feeling no power is going up to the front at all - there will always be power going to the starter relay as one post is connected to the battery - i would be looking at all the connectors first and giving them a clean Re: Arrrrrrr bike is dead,help - dilboy - 15-08-20 changed the starter solenoid and there is life in the old girl cheers all for the advice :lol :lol :lol :lol :lol |
