FZS600 Speedometer Sender?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: FZS600 Speedometer Sender?? (/showthread.php?tid=81915) |
FZS600 Speedometer Sender?? - deanflyer - 01-08-20 I went for the first ride on my Fazer since I fixed the damaged LCD odometer display. The odometer display works correctly, but the odometer mileage is not increasing. Are there separate inputs/senders for the speedometer/odometer or is it a combined unit? The speedo is working fine. If anyone can point me in the direction of the pinouts that would be great. Re: FZS600 Speedometer Sender?? - Disorderlypunk - 01-08-20 im sure its a single unit inside counting the pulses sent to the unit and increasing when it hits a certain number, if total miles aint going up then there is a good chance something has gone on the pcb inside the unit Re: FZS600 Speedometer Sender?? - deanflyer - 01-08-20 Thanks, think the eeprom might be bad. Need to investigate further.... |
