Renthal bars - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Renthal bars (/showthread.php?tid=81886) |
Renthal bars - fatbloke62 - 24-07-20 Hi ,i know the renthal 758 bars seem to be the most popular choice for the gen1, 1000 , has anyone fitted 754 bars ? , are there any issues with these regarding cable and brake line length or any fouling on the fairing Re: Renthal bars - Trebus - 24-07-20 754s on mine which fit fine with standard length cables / hoses. I have GTYR risers though which are a bit lower than standard. Re: Renthal bars - fatbloke62 - 24-07-20 Cheers trebus ,its time for me to go slightly higher for the ride comfort Re: Renthal bars - Trebus - 24-07-20 I’ll try and take a picture tomorrow. Re: Renthal bars - robbo - 24-07-20 (24-07-20, 06:42 PM)fatbloke62 link Wrote: Cheers trebus ,its time for me to go slightly higher for the ride comfortIf you're happy with the hand position on your current bars, why not just get a set of bar risers. I'd of thought 754's on stock risers would have made things a bit tight wiring harness wise, bearing in mind they're wider than stock and 35mm higher than 758's. Just a thought. Re: Renthal bars - Trebus - 25-07-20 Pictures as promised ? Re: Renthal bars - kebab19 - 25-07-20 With 754s, the control cables will all stretch ok but the standard length brake hose setup might not be quite long enough. I had one inch longer braided lines which reached the M/C fine, not sure it would have with standard length hoses. Re: Renthal bars - fatbloke62 - 26-07-20 Thanks for the info and replies guy's , I never considered bar risers :groan |
