Replacement keys - advice please! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Replacement keys - advice please! (/showthread.php?tid=81861) |
Replacement keys - advice please! - FZDick - 15-07-20 My 2008 FZ1 came with 1 key and the red master. Having lost or broke keys in the past, me thinks better get another spare black one just in case. Bought spare off eBay, arrived and cut at local key grinder, chip read as per spec found on-line, jobs a good 'un! Here's the BUT though, original black key that came with the bike now longer acknowledged by immobiliser! :'( So, programme original key, then new one won't be seen by ECU! Is this just the way it is? Only 1 key as with master allowed to be programmed at a time? Or have I just bought a DUD from the Bay? :\ So spare key to be read when original lost, which is why red master is so valuable? Any thoughts or detail please let me know, Dick Snow. Re: Replacement keys - advice please! - b1k3rdude - 15-07-20 (15-07-20, 08:17 PM)FZDick link Wrote: Here's the BUT though, original black key that came with the bike now longer acknowledged by immobiliser!
b. Re: Replacement keys - advice please! - b1k3rdude - 15-07-20 In a related note I fond this place in AUS - https://www.innerwestsecurity.com/automotive/yamaha/yamaha-fz1/ So tomoz am gonna look for some Locksmiths in the UK that can provide the same service. Re: Replacement keys - advice please! - FZDick - 16-07-20
1 - ok, programmed as found detail on the web - https://youtu.be/j4JVcC1O2ow :- -Insert RED MASTER key, turn on, start engine, stop and remove key. -Immobilizer light will start after 30 seconds -Reinsert MASTER key, turn ignition on, then off, remove MASTER and insert NEW key within 5 seconds and switch on ignition. -Remove NEW key, then re-insert and switch on, new key will enable immobilizer off and start engine. It really is that easy! OK, might have took 2 attempts, but it does add new key to ECU, albeit I can't use original, but can easily toggle between the two. 2- Ebay link below, this is not a genuine Yamaha key and doesn't claim to be:- https://www.ebay.co.uk/itm/Yamaha-Blank-Key-with-CHIP-R1-R6-FZ6-FZ1-FZ8-FJR1300-XJ6-MT10-Gold-Silver-blade/203022906755?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 3- Immobiliser emulator, really cant see the point, not risking invalid insurance as undoubtedly they know what to look for! Yamaha dealer - after being told a replacement key would be £52 + vat, then labour time ( 30 mins min) then getting key cut is the whole reason I went eBay route, £21 for blade then £5 for cutting. If I went back would be like a dog with it's tail between it's legs! Pleased key works and it can be associated to ECU, but miffed that by adding new key I loose old key functionality, but easily changed. Re: Replacement keys - advice please! - Gnasher - 16-07-20 These cheap ebay keys often do as you've found. It's all to do with them cheap rip off's not being exactly compatible, with ECU operating system. Have a search and find a better blank key transponder provider. I've not personally used these guys http://www.autolocksmithoxfordshire.co.uk/yamaha-bike-keys.html , but not heard anything bad about them and I've no idea of the costs. Re: Replacement keys - advice please! - b1k3rdude - 16-07-20 (16-07-20, 08:35 AM)FZDick link Wrote: [size=1em]Yamaha dealer - after being told a replacement key would be £52 + vat, then labour time ( 30 mins min) then getting key cut is the whole reason I went eBay route, £21 for blade then £5 for cutting.[/size]Ok I see the key being pricey, but adding labour ontop of that is ripping off the customer. I am doing a phone around atm to get a more details breakdown of costs, amnd what do when you do and dont have the read key (there are a few ECU's on ebay with either just the back key or no key at all. (16-07-20, 09:42 AM)Gnasher link Wrote: It's all to do with them cheap rip off's not being exactly compatible, with ECU operating system. Have a search and find a better blank key transponder provider.having a look now. Re: Replacement keys - advice please! - Gnasher - 16-07-20 (16-07-20, 12:10 PM)b1k3rdude link Wrote: Got more info on this Gnasher? I forgot to post the link :rollin it's there now sorry
Re: Replacement keys - advice please! - FZDick - 16-07-20 I fail to see that anything is wrong with the eBay key, as said above, the DIY programming works, and the key is seen by the ECU, and works a treat! Just that the original key will not work now! However, if I do the programming proceedure for the original key, it is then fine but the new key no longer works! So I can have either and the red key, but not red and both! Is there a "maximum number" of keys allowed by the ECU? Add a new one and it removes an existing one? Suppose it's off to main dealer and pay for programming unless anyone can advise? Re: Replacement keys - advice please! - b1k3rdude - 16-07-20 (15-07-20, 08:17 PM)FZDick link Wrote: Only 1 key as with master allowed to be programmed at a time?When you use the red master key yes, only one key can be done at a time! If you want more than one key done then go to an Autolocksmith or Yamaha dealer. Created a YISS faq thread - http://foc-u.co.uk/index.php?topic=26347.0 Re: Replacement keys - advice please! - FZDick - 17-07-20 (16-07-20, 04:07 PM)b1k3rdude link Wrote: [quote author=FZDick link=topic=26344.msg317919#msg317919 date=1594840621]Only 1 key as with master allowed to be programmed at a time?When you use the red master key yes, only one key can be done at a time! If you want more than one key done then go to an Autolocksmith or Yamaha dealer. Created a YISS faq thread - http://foc-u.co.uk/index.php?topic=26347.0 [/quote] Thanks Dude, logical answer that I can relate to! Re: Replacement keys - advice please! - b1k3rdude - 17-07-20 (17-07-20, 08:36 AM)FZDick link Wrote: Thanks Dude, logical answer that I can relate to!hah, I only learned this myself due to doing said chats with some Autolocksmiths. |
